Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Viscosity of a fluid is its resistance to shear or flow, and a measure of a fluid adhesive/cohesive or frictional properties. This arises because of the internal molecular friction within the fluid producing the frictional drag effect. There are two related measures of fluid viscosity which are known as dynamic and kinematic viscosity.
Dynamic viscosity is also termed " absolute viscosity " and is the tangential force per unit area required to move one horizontal plane with respect to the other at unit velocity when maintained a unit distance apart by the fluid.
Note that the conversion from Absolute (Dynamic) Viscosity to Kinematic Viskosity depends on fluid density . The conversions below are for fluid with density like water - where
specific gravity = 1
Absolute Viscosity | Kinematic Viscosity | ||||
centiPoise (10-3 N s/m2, cP) | p oise ( 10-1 N s/m2, P) | c entiStokes ( 10-6 m2/s, mm2/s, cSt) | s tokes (1 0-4 m2/s, S) | Saybolt Seconds Universal (SSU)1) | |
at 100 oF (37.8 oC) | at 210 oF (98.9 oC) | ||||
12) | 0.01 | 1 | 0.01 | ||
2 | 0.02 | 2 | 0.02 | 32.6 | 32.8 |
4 | 0.04 | 4 | 0.04 | 39.2 | 39.5 |
7 | 0.07 | 7 | 0.07 | 48.8 | 49.1 |
10 | 0.1 | 10 | 0.1 | 58.8 | 59.2 |
15 | 0.15 | 15 | 0.15 | 77.4 | 77.9 |
20 | 0.2 | 20 | 0.2 | 97.8 | 98.5 |
25 | 0.24 | 25 | 0.24 | 119.4 | 120.2 |
30 | 0.3 | 30 | 0.3 | 141.5 | 142.5 |
40 | 0.4 | 40 | 0.4 | 186.8 | 188.0 |
50 | 0.5 | 50 | 0.5 | 233 | 234 |
60 | 0.6 | 60 | 0.6 | 279 | 280 |
70 | 0.7 | 70 | 0.7 | 325 | 327 |
80 | 0.8 | 80 | 0.8 | 371 | 373 |
90 | 0.9 | 90 | 0.9 | 417 | 420 |
100 | 1 | 100 | 1 | 463 | 467 |
120 | 1.2 | 120 | 1.2 | 556 | 560 |
140 | 1.4 | 140 | 1.4 | 649 | |
160 | 1.6 | 160 | 1.6 | 741 | |
180 | 1.8 | 180 | 1.8 | 834 | |
200 | 2 | 200 | 2 | 927 | |
220 | 2.2 | 220 | 2.2 | 1019 | |
240 | 2.4 | 240 | 2.4 | 1112 | |
260 | 2.6 | 260 | 2.6 | 1204 | |
280 | 2.8 | 280 | 2.8 | 1297 | |
300 | 3 | 300 | 3 | 1390 | |
320 | 3.2 | 320 | 3.2 | 1482 | |
340 | 3.4 | 340 | 3.4 | 1575 | |
360 | 3.6 | 360 | 3.6 | 1668 | |
380 | 3.8 | 380 | 3.8 | 1760 | |
400 | 4 | 400 | 4 | 1853 | |
420 | 4.2 | 420 | 4.2 | 1946 | |
440 | 4.4 | 440 | 4.4 | 2038 | |
460 | 4.6 | 460 | 4.6 | 2131 | |
480 | 4.8 | 480 | 4.8 | 2224 | |
500 | 5 | 500 | 5 | 2316 | |
550 | 5.5 | 550 | 5.5 | ||
600 | 6 | 600 | 6 | ||
700 | 7 | 700 | 7 | ||
800 | 8 | 800 | 8 | ||
900 | 9 | 900 | 9 | ||
1000 | 10 | 1000 | 10 | ||
1100 | 11 | 1100 | 11 | ||
1200 | 12 | 1200 | 12 | ||
1300 | 13 | 1300 | 13 | ||
1400 | 14 | 1400 | 14 | ||
1500 | 15 | 1500 | 15 | ||
1600 | 16 | 1600 | 16 | ||
1700 | 17 | 1700 | 17 | ||
1800 | 18 | 1800 | 18 | ||
1900 | 19 | 1900 | 19 | ||
2000 | 20 | 2000 | 20 | ||
2100 | 21 | 2100 | 21 | ||
2200 | 22 | 2200 | 22 | ||
2300 | 23 | 2300 | 23 | ||
2400 | 24 | 2400 | 24 | ||
2500 | 25 | 2500 | 25 | ||
3000 | 30 | 3000 | 30 | ||
3500 | 35 | 3500 | 35 | ||
4000 | 40 | 4000 | 40 | ||
4500 | 45 | 4500 | 45 | ||
5000 | 50 | 5000 | 50 | ||
5500 | 55 | 5500 | 55 | ||
6000 | 60 | 6000 | 60 | ||
6500 | 65 | 6500 | 65 | ||
7000 | 70 | 7000 | 70 | ||
7500 | 75 | 7500 | 75 | ||
8000 | 80 | 8000 | 80 | ||
8500 | 85 | 8500 | 85 | ||
9000 | 90 | 9000 | 90 | ||
9500 | 95 | 9500 | 95 | ||
15000 | 150 | 15000 | 150 | ||
20000 | 200 | 20000 | 200 | ||
30000 | 300 | 30000 | 300 | ||
40000 | 400 | 40000 | 400 | ||
50000 | 500 | 50000 | 500 | ||
60000 | 600 | 60000 | 600 | ||
70000 | 700 | 70000 | 700 | ||
80000 | 800 | 80000 | 800 | ||
90000 | 900 | 90000 | 900 | ||
100000 | 1000 | 100000 | 1000 | ||
125000 | 1250 | 125000 | 1250 | ||
150000 | 1500 | 150000 | 1500 | ||
175000 | 1750 | 175000 | 1750 | ||
200000 | 2000 | 200000 | 2000 |
1) The Saybolt Universal SUS viscosity equivalent (SSU or SUS) to a given kinematic viscosity varies with the temperature at which the determination is made. Check ASTM D 2161 "Standard Practice for Conversion of Kinematic Viscosity to Saybolt Universal Viscosity or to Saybolt Furol Viscosity"
2) Water at 68.4 oF (20.2 oC) has an absolute viscosity of one - 1 - centiPoise .
Note! Viscosity conversions are based on fluids with specific gravity of one.
Saybolt Second Universal (SSU) Viscosity at temperatures other than 100 or 210 oF
At temperatures other than 100 or 210°F, convert kinematic viscosity to Saybolt Universal viscosity with
Ut = U100°F (1 + 0.000061 (t - 100)) (1)
Ut = Saybolt Second Universal (SSU) viscosity at temperature t (°F)
U100°F = Saybolt Second Universal (SSU) viscosity at 100°F in Saybolt Universal seconds equivalent to kinematic viscosity in centiStokes at temperature t (°F)
Download and print Kinematic Viscosity Unit Converting Chart
• Pumps
• Viscosities
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Drag Coefficient
The drag coefficient quantifies the drag or resistance of an object in a fluid environment.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Fuels - Viscosities vs. Temperatures
Viscosities of fuel oils vs. temperature.
Oil Pipes - Pressure Loss vs. Oil Flow
Pressure drop in oil pipes - viscosities ranging 100 - 600 Saybolt Universal Seconds.
Viscosities and densities of SAE Grade oils.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
