Drag Coefficient
Any object moving through a fluid experiences drag - the net force in the direction of flow due to pressure and shear stress forces on the surface of the object.
The drag force can be expressed as:
Fd = cd 1/2 ρ v2 A (1)
Fd = drag force (N)
cd = drag coefficient
ρ = density of fluid (1.2 kg/m3 for air at NTP)
v = flow velocity (m/s)
A = characteristic frontal area of the body (m2)
The drag coefficient is a function of several parameters like shape of the body, Reynolds Number for the flow, Froude number, Mach Number and Roughness of the Surface.
The characteristic frontal area - A - depends on the body.
Objects drag coefficients are mostly results of experiments. The drag coefficients for some common bodies are indicated below:
Type of Object | Drag Coefficient - cd - | Frontal Area |
Laminar flat plate (Re=106) | 0.001 | |
Dolphin | 0.0036 | wetted area |
Turbulent flat plate (Re=106) | 0.005 | |
Subsonic Transport Aircraft | 0.012 | |
Supersonic Fighter,M=2.5 | 0.016 | |
Streamlined body | 0.04 | π / 4 d2 |
Airplane wing, normal position | 0.05 | |
Sreamlined half-body | 0.09 | |
Long stream-lined body | 0.1 | |
Bicycle - Streamlined Velomobile | 0.12 | 5 ft2 (0.47 m2) |
Airplane wing, stalled | 0.15 | |
Modern car like a Tesla model 3 or model Y | 0.23 | |
Toyota Prius, Tesla model S | 0.24 | frontal area |
Tesla model X | ||
Sports car, sloping rear | 0.2 - 0.3 | frontal area |
Common car like Opel Vectra (class C) | 0.29 | frontal area |
Hollow semi-sphere facing stream | 0.38 | |
Bird | 0.4 | frontal area |
Solid Hemisphere | 0.42 | π / 4 d2 |
Sphere | 0.5 | |
Saloon Car, stepped rear | 0.4 - 0.5 | frontal area |
Bike - Drafting behind an other cyclist | 0.5 | 3.9 ft2 (0.36 m2) |
Convertible, open top | 0.6 - 0.7 | frontal area |
Bus | 0.6 - 0.8 | frontal area |
Old Car like a T-ford | 0.7 - 0.9 | frontal area |
Cube | 0.8 | s2 |
Bike - Racing | 0.88 | 3.9 ft2 (0.36 m2) |
Bicycle | 0.9 | |
Tractor Trailed Truck | 0.96 | frontal area |
Truck | 0.8 - 1.0 | frontal area |
Person standing | 1.0 – 1.3 | |
Bike - Upright Commuter | 1.1 | 5.5 ft2 (0.51 m2) |
Thin Disk | 1.1 | π / 4 d2 |
Solid Hemisphere flow normal to flat side | 1.17 | π / 4 d2 |
Squared flat plate at 90 deg | 1.17 | |
Wires and cables | 1.0 - 1.3 | |
Person (upright position) | 1.0 - 1.3 | |
Hollow semi-cylinder opposite stream | 1.2 | |
Ski jumper | 1.2 - 1.3 | |
Hollow semi-sphere opposite stream | 1.42 | |
Passenger Train | 1.8 | frontal area |
Motorcycle and rider | 1.8 | frontal area |
Long flat plate at 90 deg | 1.98 | |
Rectangular box | 2.1 |
Example - Air Resistance Force acting on a Normal Car
The force required to overcome air resistance for a normal family car with drag coefficient 0.29 and frontal area 2 m2 in 90 km/h can be calculated as:
Fd = 0.29 1/2 (1.2 kg/m3) ((90 km/h) (1000 m/km) / (3600 s/h))2 (2 m2)
= 217.5 N
- compare car air resistance with car rolling resistance
The work done to overcome the air resistance in one hour driving (90 km) can be calculated as
Wd = (217.5 N) (90 km) (1000 m/km)
= 19575000 (Nm, J)
The power required to overcome the air resistance when driving 90 km/h can be calculated as
Pd = (217.5 N) (90 km/h) (1000 m/km) (1/3600 h/s)
= 5436 (Nm/s, J/s, W)
= 5.4 (kW)
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car Fuel Consumption - liter/100 km
Calculate fuel consumption in liter per km - consumption chart and calculator.
Driving Distances between European Cities
Driving distance between some major European cities.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Froude Number
Introduction to the Froude Number.
Fuel Consumption - mpg
Calculate fuel consumption in miles per gallon - mpg - calculator and consumption charts.
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Piston Engines - Displacement
Calculate piston engine displacement.
Rolling Resistance
Rolling friction and rolling resistance.
Target - Volume Flow Meters
Introduction to the target flow meters principles.
Vehicle - Distance Traveled vs. Velcocity and Time Used (mph)
Speed (mph) and time (hours) and distance traveled (miles) chart.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Wind Load vs. Wind Speed
Wind load on surface - Wind load calculator.
