Vehicle - Distance Traveled vs. Velcocity and Time Used (mph)
Distance Calculator
Time to Travel Distance Calculator
Speed, time and distance traveled are indicated in the chart below.
Download and Print Vehicle - Distance Traveled vs. Velocity and Time Chart
Miscellaneous
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car - Traction Force
Adhesion and tractive force between car wheel and surface.
Car Acceleration
Car acceleration calculator.
Car Fuel Consumption - liter/100 km
Calculate fuel consumption in liter per km - consumption chart and calculator.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Drag Coefficient
The drag coefficient quantifies the drag or resistance of an object in a fluid environment.
Driving Distances between European Cities
Driving distance between some major European cities.
Fuel Consumption - mpg
Calculate fuel consumption in miles per gallon - mpg - calculator and consumption charts.
Fuel Consumption Converter
Convert between fuel consumption units like US MPG, Imperial MPG, litre/nm, litre/100 km and km/litre
Impact Force
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Rolling Resistance
Rolling friction and rolling resistance.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
