Minutes to Decimal Hours Conversion: Chart & Calculator
Minutes can be converted to decimal hours
d = m / 60                           (1)
d = decimal hours
m = minutes
Minutes to Decimal Hours Calculator
Decimal Hours vs. Minutes
MinutesDecimal Hours
1 0.017
2 0.033
3 0.050
4 0.067
5 0.083
6 0.100
7 0.117
8 0.133
9 0.150
10 0.167
11 0.183
12 0.200
13 0.217
14 0.233
15 0.250
16 0.267
17 0.283
18 0.300
19 0.317
20 0.333
21 0.350
22 0.367
23 0.383
24 0.400
25 0.417
26 0.433
27 0.450
28 0.467
29 0.483
30 0.500
31 0.517
32 0.533
33 0.550
34 0.567
35 0.583
36 0.600
37 0.617
38 0.633
39 0.650
40 0.667
41 0.683
42 0.700
43 0.717
44 0.733
45 0.750
46 0.767
47 0.783
48 0.800
49 0.817
50 0.833
51 0.850
52 0.867
53 0.883
54 0.900
55 0.917
56 0.933
57 0.950
58 0.967
59 0.983
60 1.000
Miscellaneous
Latitude and Longitude Converter: Convert Between Degrees, Minutes, Seconds, and Decimal Units
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa).
Minutes vs. Degrees - Converting Chart
Convert from minutes to degrees.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Radians vs. Degrees - Definition and Conversions
UTM to Latitude and Longitude Converter: Convert UTM Coordinates to Geographic Coordinates
Free online UTM to Latitude and Longitude coordinates converter.
