Minutes vs. Degrees - Converting Chart
There are 60 minutes in one degree
- 1 degree = 60 minutes
- and minutes can be converted to degrees as indicated below.
Minutes to Degrees Calculator
Minutes | Degrees |
1 | 0.0167 |
2 | 0.0333 |
3 | 0.05 |
4 | 0.0667 |
5 | 0.0833 |
6 | 0.1 |
7 | 0.1167 |
8 | 0.1333 |
9 | 0.15 |
10 | 0.1667 |
11 | 0.1833 |
12 | 0.2 |
13 | 0.2167 |
14 | 0.2333 |
15 | 0.25 |
16 | 0.2667 |
17 | 0.2833 |
18 | 0.3 |
19 | 0.3167 |
20 | 0.3333 |
21 | 0.35 |
22 | 0.3667 |
23 | 0.3833 |
24 | 0.4 |
25 | 0.4167 |
26 | 0.4333 |
27 | 0.45 |
28 | 0.4667 |
29 | 0.4833 |
30 | 0.5 |
31 | 0.5167 |
32 | 0.5333 |
33 | 0.55 |
34 | 0.5667 |
35 | 0.5833 |
36 | 0.6 |
37 | 0.6167 |
38 | 0.6333 |
39 | 0.65 |
40 | 0.6667 |
41 | 0.6833 |
42 | 0.7 |
43 | 0.7167 |
44 | 0.7333 |
45 | 0.75 |
46 | 0.7667 |
47 | 0.7833 |
48 | 0.8 |
49 | 0.8167 |
50 | 0.8333 |
51 | 0.85 |
52 | 0.8667 |
53 | 0.8833 |
54 | 0.9 |
55 | 0.9167 |
56 | 0.9333 |
57 | 0.95 |
58 | 0.9667 |
59 | 0.9833 |
60 | 1 |
• Mathematics
Latitude and Longitude Converter: Convert Between Degrees, Minutes, Seconds, and Decimal Units
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa).
Minutes to Decimal Hours Conversion: Chart & Calculator
Convert minutes to descimal hours.
Radians vs. Degrees - Definition and Conversions
Slope Calculator: Convert Between Degrees, Gradient, and Grade
Convert slopes pitch between degrees, gradients and grades.
Steradian
A unit of solid-angle measure in the International System of Units (SI)
UTM to Latitude and Longitude Converter: Convert UTM Coordinates to Geographic Coordinates
Free online UTM to Latitude and Longitude coordinates converter.
