Steradian
The steradian is a unit of solid-angle measure in the International System of Units (SI). It is defined as
  • the solid angle of a sphere subtended by a portion of the surface whose area is equal to the square of the sphere’s radius.
The complete surface area of a sphere is 4π times the square of its radius and
  • the total solid angle about a point is equal to 4π steradians.
Mathematics
Angle Converter
Converting between angle units.
Minutes vs. Degrees - Converting Chart
Convert from minutes to degrees.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Radians vs. Degrees - Definition and Conversions
SI System
An introduction to the SI metric system.
