Angle Converter
Angle Converter
Online angle units converter
Convert between angle units - degrees, radians, grades, minutes and more:
Converting between Degrees and Radians
Degrees are commonly used in "humans" language and radians are commonly used in computer languages. Since there is 360 degrees and 2 π radians in a circle
- degrees can be converted to radians with the equation
θ = 2 π Φ / 360                                         (1)
θ = radians
Φ = degrees
- and radians can be converted to degrees with the equation
Φ = 360 θ / (2 π)                                        (2)
Example - Converting between Degrees and Radians
90 degrees can be converted to radians with eq. (1) as
θ = 2 π (90 degrees) / 360
= 1.57 radians
1 radian can be converted to degrees with eq. (2) as
Φ = 360 (1 radian) / (2 π)
= 57.3 degrees
Turns, Radians and Degrees
Turns vs. Radians vs. Degrees
TurnsRadiansDegrees
0 0 0
1/24 π/12 15
1/12 π/6 30
1/8 π/4 45
1/(2 π) 1 57.3..
1/6 π/3 60
1/4 π/2 90
1/3 2π/3 120
1/2 π 180
3/4 3π/2 270
1 360
Basics
Mathematics
Steradian
A unit of solid-angle measure in the International System of Units (SI)
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Unit Factor Method
