Impact Force
The dynamic kinetic energy of a moving object, like a falling ball or a driving car, can be expressed as
E = 1/2 m v2 (1)
E = kinetic (dynamic) energy (J, ft lb)
m = mass of the object (kg, slugs )
v = velocity of the object (m/s, ft/s)
In an impact - like a car crash - the work made by the impact force slowing down an moving object over a distance by deforming the crumple zone can be expressed as
W = Favg s (2)
W = work done (J, ft lb)
Favg = average impact force during deformation (N, lbf)
s = deformation distance, crumple zone (m, ft)
When a crumple zone deforms in a car crash the average impact force is designed to be as constant as possible.
In an impact where the object is not deformed - the work made by the impact force slowing down the moving object equals to the work done by a spring force - and can be expressed as
W = 1/2 Fmax s
= 1/2 k s2 (2b)
Fmax = maximum force at the end of the deformation (N, lbf)
k = spring constant
s = deformation distance (m, ft)
In a car crash the dynamic energy is converted to work and equation 1 and 2 can be combined to
Favg s = 1/2 m v2 (3)
The average impact force can be calculated as
Favg = 1/2 m v2 / s (3b)
The deformation slow-down distance can be calculated as
s = 1/2 m v2 / Favg (3c)
Note! - The deformation slow-down distance is very important and the key to limit the forces acting on passengers in a car crash.
Example - Car Crash
A car with a mass of 2000 kg drives with speed 60 km/h (16.7 m/s) before it crashes into a massive concrete wall. The front of the car impacts 0.5 m (the deformation distance).
The impact force can be calculated as
Fmax = 1/2 (2000 kg) (16.7 m/s)2 / (0.5 m)
= 558 kN
Note that the gravitation force (weight) acting on the car is only
Fw = m g
= (2000 kg) (9.81 m/s2)
= 19.6 kN
The impact creates a force 28 times gravity!!
A person sitting inside the car with seat belts on will de-accelerate with a force 28 times gravity . Note that the National Highway Traffic Safety Administration (NHTSA) states that "the maximum chest acceleration shall not exceed 60 times gravity for time periods longer than 3 milliseconds ". For a car crash with 90 km/h (25 m/s) the de-acceleration will be 64 times gravity (same parameters as above).
- 60 mph = 96.6 km/h
Impact Force from a Falling Object
The dynamic energy in a falling object at the impact moment when it hits the ground can be calculated as
E = Fweight h
= m ag h (4)
Fweight = force due to gravity - or weight (N, lbf)
ag = acceleration of gravity (9.81 m/s2, 32.17405 ft/s2)
h = falling height (m)
If the dynamic energy from the fall is converted to impact work - equation 2 and 4 can be combined to
Favg s = m ag h (5)
The impact force can be expressed as
Favg = m ag h / s (5b)
The deformation slow-down distance can be expressed as
s = m ag h / Favg (5c)
Example - a Falling Car
The same car as above falls from height 14.2 m and crashes on the crumple zone with the front down on a massive concrete tarmac. The front impacts 0.5 m (slow down distance) as above. The impact force can be calculated as
Favg = (2000 kg) (9.81 m/s2) (14.2 m) / (0.5 m)
= 558 kN
Note! - a car crash in 90 km/h (25 m/s) compares to a fall from 32 m !!
Example - a Person falling from a Table
A person with weight (gravitational force) of 200 lbs (lbf) falls from a 4 feet high table.
The energy of the falling body when it hits the ground can be calculated using (4) as
E = (200 lbf) (4 ft)
= 800 ft lb
The impact on a human body can be difficult to determine since it depends on how the body hits the ground - which part of the body, the angle of the body and/or if hands are used to protect the body and so on.
For this example we use an impact distance of 3/4 inch (0.0625 ft) to calculate the impact force:
Favg = (800 ft lb) / (0.0625 ft)
= 12800 lbf
In metric units - person with weight 90 kg, falling distance 1.2 m and impact distance 2 cm :
E = (90 kg) (9.81 m/s2) (1.2 m)
= 1059 J
Favg = (1059 J) / (0.02 m)
= 53 kN
• Dynamics
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car Acceleration
Car acceleration calculator.
Car Fuel Consumption - liter/100 km
Calculate fuel consumption in liter per km - consumption chart and calculator.
Conservation of Momentum
The momentum of a body is the product of its mass and velocity - recoil calculator.
Driving Distances between European Cities
Driving distance between some major European cities.
Force
Fuel Consumption - mpg
Calculate fuel consumption in miles per gallon - mpg - calculator and consumption charts.
Impulse and Impulse Force
Forces acting a very short time are called impulse forces.
Jet Propulsion
Calculate the propulsive discharge force or thrust induced by an incompressible jet flow.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Piston Engines - Displacement
Calculate piston engine displacement.
Rolling Resistance
Rolling friction and rolling resistance.
Vehicle - Distance Traveled vs. Velcocity and Time Used (mph)
Speed (mph) and time (hours) and distance traveled (miles) chart.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
Work done by Force
Work done by a force acting on an object.
