Reynolds Number
Reynolds Number - the non-dimensional velocity - can be defined as the ratio
- inertia force (ρ u L) to viscous or friction force (μ)
and interpreted as the ratio
- dynamic pressure (ρ u2) to shearing stress (μ u / L)
Reynolds Number can therefore be expressed as
Re = ρ u L / μ
= ρ u2/ (μ u / L)
= u L / ν (1)
Re = Reynolds Number (non-dimensional)
ρ = density (kg/m3, lbm /ft3 )
u = velocity based on the actual cross section area of the duct or pipe (m/s, ft/s)
μ = dynamic viscosity (Ns/m2, lbm /s ft)
L = characteristic length (m, ft)
ν = μ / ρ = kinematic viscosity (m2/s, ft2/s)
Reynolds Number for Flow in Pipe or Duct
For a pipe or duct the characteristic length is the hydraulic diameter .
L = d h
d h = hydraulic diameter (m, ft)
The Reynolds Number for the flow in a duct or pipe can with the hydraulic diameter be expressed as
Re = ρ u d h / μ
= u d h / ν (2)
Reynolds Number for a Pipe or Duct in Imperial Units
The Reynolds number for a pipe or duct expressed in Imperial units
Re = 7745.8 u d h / ν (2a)
Re = Reynolds Number (non dimensional)
u = velocity (ft/s)
d h = hydraulic diameter (in)
ν = kinematic viscosity (cSt) (1 cSt = 10-6 m2/s )
The Reynolds Number can be used to determine if flow is laminar, transient or turbulent. The flow is
- laminar - when Re < 2300
- transient - when 2300 < Re < 4000
- turbulent - when Re > 4000
In practice laminar flow is only actual for viscous fluids - like crude oil, fuel oil and other oils.
Example - Calculate Reynolds Number
A Newtonian fluid with a dynamic or absolute viscosity of 0.38 Ns/m2 and a specific gravity of 0.91 flows through a 25 mm diameter pipe with a velocity of 2.6 m/s .
Density can be calculated from the specific gravity of the fluid and the density of the specific gravity reference water 1000 kg/m3 - as
ρ = 0.91 (1000 kg/m3 )
= 910 kg/m3
Reynolds Number can then be calculated using equation (1) like
Re = (910 kg/m3 ) (2.6 m/s) (25 mm) (10-3 m/mm) / (0.38 Ns/m2)
= 156 ((kg m / s2)/N)
= 156 ~ Laminar flow
1 (N) = 1 (kg m / s2)
Online Reynolds Calculator
Density and absolute (dynamic) viscosity is Known
This calculator can be used if density and absolute (dynamic) viscosity of the fluid is known. The calculator is valid for incompressible flow - flow with fluids or gases without compression - as typical for air flows in HVAC systems or similar. The calculator is generic and can be used for metric and imperial units as long as the use of units are consistent.
Default values are for air at 60 oF , 2 atm pressure and density 0.146 lbm /ft3 , flowing 20 ft/s between two metal sheets with characteristic length 0.5 ft. Dynamic (absolute) viscosity is 1.22 10 -5 lbm /s ft.
Kinematic viscosity is known
The calculator below can be used when kinematic viscosity of the fluid is known. The calculator is generic and can be used for metric and imperial units as long as the use of units are consistent.
Default values are for water at 20 oC with kinematic viscosity 1.004 10-6 m2/s in a schedule 40 steel pipe . The characteristic length (or hydraulic diameter) of the pipe is 0.102 m.
• Piping Systems
• Water Systems
Colebrook Equation
Darcy-Weisbach Equation - Major Pressure and Head Loss due to Friction
Dimensionless Numbers
Physical and chemical dimensionless quantities - Reynolds number, Euler, Nusselt, and Prandtl number - and many more.
Fluid Flow - Entrance Length and Developed Flow
The entrance length is the length in a tube or duct after an obstruction - until the flow velocity profile is fully developed.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
Laminar Flow - Friction Coefficients
Calculate friction coefficients for laminar fluid flow.
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Moody Diagram
Calculate fluid flow friction coefficients from a Moody diagram.
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
