Fluid Flow - Entrance Length and Developed Flow
A fluid flow need some length to fully develop the velocity profile after passing through components like bends, valves, pumps, turbines or similar.
Entrance Length
The entrance length can be expressed with the dimensionless Entrance Length Number as
El = le / d                           (1)
El = Entrance Length number
le = length to fully developed velocity profile (m, ft)
d = tube or duct diameter (m, ft)
Entrance Length Number for Laminar Flow
The Entrance length number correlates with the Reynolds Number  and for laminar flow the relation can be expressed as:
Ellaminar = 0.06 Re                       (2)
Re = Reynolds Number
Entrance Length Number for Turbulent Flow
The Entrance length number correlation with the Reynolds Number for turbulent flow can be expressed as:
Elturbulent = 4.4 Re1/6                         (3)
Fluid Mechanics
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Poiseuille's Formula
Calculate the volume flow discharged through a smooth-walled circular pipe.
