Laminar, Transitional and Turbulent Flow
There are in general three types of fluid flow in pipes
- laminar
- turbulent
- transient
Laminar flow
Laminar flow generally happens when dealing with small pipes and low flow velocities. Laminar flow can be regarded as a series of liquid cylinders in the pipe, where the innermost parts flow the fastest, and the cylinder touching the pipe isn't moving at all.
Shear stress in a laminar flow depends almost only on viscosity - μ - and is independent of density - ρ.
Turbulent flow
In turbulent flow vortices, eddies and wakes make the flow unpredictable. Turbulent flow happens in general at high flow rates and with larger pipes.
Shear stress in a turbulent flow is a function of density - ρ.
Transitional flow
Transitional flow is a mixture of laminar and turbulent flow, with turbulence in the center of the pipe, and laminar flow near the edges. Each of these flows behave in different manners in terms of their frictional energy loss while flowing and have different equations that predict their behavior.
Turbulent or laminar flow is determined by the dimensionless Reynolds Number.
Reynolds Number
The Reynolds number is important in analyzing any type of flow when there is substantial velocity gradient (i.e. shear.) It indicates the relative significance of the viscous effect compared to the inertia effect. The Reynolds number is proportional to inertial force divided by viscous force.
The flow is
- laminar when Re < 2300
- transient when 2300 < Re < 4000
- turbulent when Re > 4000
Fluid Flow - Entrance Length and Developed Flow
The entrance length is the length in a tube or duct after an obstruction - until the flow velocity profile is fully developed.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pressure Gradient Diagrams
Static pressure graphical presentation throughout a fluid flow system.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
