Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute or dynamic viscosity is used to calculate Reynolds Number to determine if a fluid flow is laminar, transient or turbulent.
The absolute or dynamic viscosity of water depends on the temperature as indicated below:
TemperatureAbsolute - Dynamic - Viscosity
(cP)
(oF)(oC)
32 0 1.794
40 4.4 1.546
50 10.0 1.310
60 15.6 1.129
70 21.1 0.982
80 26.7 0.862
90 32.2 0.764
100 37.8 0.682
120 48.9 0.559
140 60.0 0.470
160 71.1 0.401
180 82.2 0.347
200 93.3 0.305
  •  1 cP = 0.01 poise = 0.01 gram per cm second = 0.001 Pascal second = 1 milliPascal second = 0.001 N.s/m2
  • Convert viscosity
Water - Relative Viscosity vs. Higher Pressure and Temperature
Fluid Mechanics
Viscosities
Cooling Water - Pipe Lines
Sizing cooling water pipe lines - maximum allowable flow, velocity and pressure drops.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Reynolds Number
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Viscosity Converting Chart
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water - Thermophysical Properties
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
