Dynamic (Absolute) Viscosity Units Online Calculator
The calculator below can be used to convert between common absolute or dynamic viscosity units:
A Dynamic (Absolute) Viscosity Units Converting Table
The table below can be used to convert between common dynamic or absolute viscosity units.
Convert from | Multiply by | ||||
Convert to | |||||
Poiseuille (Pa s) | Poise (dyne s/cm2) (g/cm s) | centiPoise | kg/m h | kgf s/m2 | |
Poiseuille (Pa s) |
1 | 10 | 103 | 3.63×103 | 0.102 |
0.1 | 1 | 100 | 360 | 0.0102 |
centiPoise | 0.001 | 0.01 | 1 | 3.6 | 0.00012 |
kg/m h | 2.78×10-4 | 0.00278 | 0.278 | 1 | 2.83×10-5 |
kgf s/m2 | 9.81 | 98.1 | 9.81×103 | 3.53×104 | 1 |
lbf s/inch2(Reyns) |
6.89×103 | 6.89×104 | 6.89×106 | 2.48×107 | 703 |
lbf s/ft2 | 47.9 | 479 | 4.79×104 | 1.72×105 | 0.0488 |
lbf h/ft2 | 1.72×105 | 1.72×106 | 1.72×108 | 6.21×108 | 1.76×104 |
lb/ft s | 1.49 | 14.9 | 1.49×103 | 5.36×103 | 0.152 |
lb/ft h | 4.13×10-4 | 0.00413 | 0.413 | 1.49 | 4.22×10-5 |
Convert to | |||||
lbf s/inch2(Reyns) | lbf s/ft2 | lbf h/ft2 | lb/ft s | lb/ft h | |
Poiseuille (Pa s) |
1.45×10-4 | 0.0209 | 5.8×10-6 | 0.672 | 2.42×103 |
Poise (dyne s/cm2 = g/cm s) |
1.45×10-5 | 0.00209 | 5.8×10-7 | 0.0672 | 242 |
centiPoise | 1.45×10-7 | 2.09×10-5 | 5.8×10-9 | 0.000672 | 2.42 |
kg/m h | 4.03×10-8 | 5.8×10-6 | 1.61×10-9 | 0.000187 | 0.672 |
kgf s/m2 | 0.00142 | 20.5 | 5.69×10-5 | 6.59 | 2.37×104 |
lbf s/inch2 | 1 | 144 | 0.04 | 4.63×103 | 1.67×107 |
lbf s/ft2 | 0.00694 | 1 | 0.000278 | 32.2 | 1.16×105 |
lbf h/ft2 | 25 | 3.6×103 | 1 | 1.16×105 | 4.17×108 |
lb/ft s | 0.000216 | 0.0311 | 8.63×10-6 | 1 | 3.6×103 |
lb/ft h | 6 10-8 | 8.633×10-6 | 2.4×10-9 | 0.000278 | 1 |
Download and print Dynamic Viscosity Unit Converter chart
Common Dynamic or Absolute Viscosity Units
- 1 Pascal second (Poiseuille) = 1000 Centipoise
- 1 Pascal second (Poiseuille) = 10 Dyne second / centimetre2
- 1 Pascal second (Poiseuille) = 0.0102 Gram force seconds / centimetre2
- 1 Pascal second (Poiseuille) = 10 Gram / centimetre second
- 1 Pascal second (Poiseuille) = 0.102 Kilogram force seconds / metre2
- 1 Pascal second (Poiseuille) = 3600 Kilogram / metre hour
- 1 Pascal second (Poiseuille) = 1 Kilogram / metre second
- 1 Pascal second (Poiseuille) = 107 Micropoise
- 1 Pascal second (Poiseuille) = 1 Newton Second / metre2
- 1 Pascal second (Poiseuille) = 10 Poise
- 1 Pascal second (Poiseuille) = 0.0209 Pound force seconds / ft2
- 1 Pascal second (Poiseuille) = 0.000145 Pound force seconds / in2
- 1 Pascal second (Poiseuille) = 2419.1 Pound / foot hour
- 1 Pascal second (Poiseuille) = 0.672 Pound / foot second
- 1 Pascal second (Poiseuille) = 0.056 Pound / inch second
- 1 Pascal second (Poiseuille) = 0.672 Poundal seconds / ft2
- 1 Pascal second (Poiseuille) = 0.000145 Reyn
- 1 Pascal second (Poiseuille) = 0.0209 Slugs / foot second
• Viscosities
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Poiseuille's Formula
Calculate the volume flow discharged through a smooth-walled circular pipe.
Viscosities and densities of SAE Grade oils.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Unit Factor Method
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water Viscosity: Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
