SAE Multigrade | Viscosity | Density | ||||
Centistokes | 10-6 reyns (lb s/in2) | kg/m3 | lb/in3 | |||
40 oC | 100 oC | 104 oF | 212 oF | |||
5W-30 | 64 | 11 | 8.2 | 1 | 860 | 0.0311 |
10W-30 | 69 | 11 | 8.8 | 1.1 | 865 | 0.0312 |
10W-40 | 94 | 14.3 | 11.9 | 1.5 | 865 | 0.0312 |
20W-50 | 166 | 18.7 | 21.3 | 2.7 | 872 | 0.0315 |
• Densities
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Grease - Temperature Limits
Temperature limits for grease - a combination of oil and thickener.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Lubrication - Temperature Limits
Temperature limits for lubricating oils.
Oil Pipes - Pressure Loss vs. Oil Flow
Pressure drop in oil pipes - viscosities ranging 100 - 600 Saybolt Universal Seconds.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
