Grease - Temperature Limits
Grease is a combination of mineral or synthetic oil and thickener - also called soap. Rust and oxidation inhibitors are also often added.
  • Oil content ranges 70 - 97% - commonly about 80%
The temperature limit for a grease is limited by the oil and thickener used.
Grease ThickenerTemperature Limits
(oF)(oC)
Aluminum 180 82
Barium 225 107
Calcium 170 77
Lithium 300 149
Sodium 250 121
Synthetics < 500 < 260
Miscellaneous
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Elastomers
Natural and syntetic rubbers guide.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Hydraulic Oil Pump - Horsepower vs. Pressure and Volume Flow
The power required for hydraulic pumping.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Viscosities and densities of SAE Grade oils.
