Hydraulic Oil Pump - Horsepower vs. Pressure and Volume Flow
Horsepower required by a hydraulic pump can be calculated as
P HP = q p / 1714 (1)
P HP = horsepower (HP)
q = flow (gpm)
p = required pressure (psi)
- 1 gpm (US) =6.30888x10 -5 m 3 /s = 0.227 m 3 /h = 0.06309 dm 3 (litre)/s = 2.228x10 -3 ft 3 /s = 0.1337 ft 3 /min = 0.8327 gpm (UK)
- 1 psi (lb/in 2 ) = 144 psf (lb f /ft 2 ) = 6,894.8 Pa (N/m 2 ) = 6.895x10 -3 N/mm 2 = 6.895x10 -2 bar
- 1 hp = 745.7 W
Example - Hydraulic Pump
The horsepower required by a a pump with flow 20 gpm and 1500 psi increase in pressure can be calculated as
P HP = (20 gpm) (1500 psi) / 1714
= 17.5 HP
Efficiency
Note that the equation above is for a pump with 100% efficiency - which in the practial life is never true. An overall efficiency of 80 - 95% is common.
The equation above (1) can be modified to
P HP = q p / ((μ / 100) 1714) (2)
μ = overall efficiency (%)
• Hydraulics and Pneumatics
Hydraulic and pneumatic systems - fluids, forces, pumps and pistons.
Grease - Temperature Limits
Temperature limits for grease - a combination of oil and thickener.
Hydraulic Cylinder Area vs. Diameter
Typical hydraulic cylinders and acting area vs. cylinder diameter.
Hydraulic Cylinders - Volume Displacement
The volumetric displacement of hydraulic cylinders.
Hydraulic Force vs. Pressure and Cylinder Size
Calculate hydraulic cylinder force.
Hydraulic Pump Motor Sizing
Motor size vs. flow rate, shaft torque, shaft power and hydraulic power.
Hydraulic Pump Volume Capacity
Calculate hydraulic pump volume capacity.
