The force produced on the opposite of rod side (2) - can be expressed as
F 2 = P 2 (π d 2 2 / 4) (2)
F 2 = rod force (lb, N)
P 2 = pressure in the cylinder (opposite rod) ( psi, N/mm 2 )
- when pressure act on opposite side of rod.
- when pressure act on the same side of the rod.
Hydraulic and pneumatic systems - fluids, forces, pumps and pistons.
A Block Flow Diagram is a schematic illustration of a major process.
The force ratio is the load force versus the effort force.
Typical hydraulic cylinders and acting area vs. cylinder diameter.
The volumetric displacement of hydraulic cylinders.
Pascal's law and the hydraulic force acting in fluids.
The power required for hydraulic pumping.
Motor size vs. flow rate, shaft torque, shaft power and hydraulic power.
Calculate hydraulic pump volume capacity.
