Hydraulic Cylinders - Volume Displacement
The volume displacement of a hydraulic cylinder can be calculated as
q = A s / 231                                     (1)
q = volume displacement (gal)
A = cylinder area (in2)
s = cylinder stroke (in)
  • 1 in (inch) = 25.4 mm = 2.54 cm = 0.0254 m = 0.08333 ft
  • 1 in2 = 6.452 cm2 = 6.452×10-4 m2 = 6.944×10-3 ft2
  • 1 gal (US) = 3.785×10-3 m3 = 3.785 dm3 (liter) = 0.13368 ft3
Example - Hydraulic Cylinder and Volumetric Displacement
A 4" cylinder with a cylinder area 12.57 in2 makes a 30" stroke. The cubic displacement can be calculated as
 q = (12.57 in2) (30 in) / 231
    = 1.63 gal
Hydraulics and Pneumatics
Hydraulic and pneumatic systems - fluids, forces, pumps and pistons.
Hydraulic Cylinder Area vs. Diameter
Typical hydraulic cylinders and acting area vs. cylinder diameter.
Hydraulic Force vs. Pressure and Cylinder Size
Calculate hydraulic cylinder force.
Hydraulic Oil Pump - Horsepower vs. Pressure and Volume Flow
The power required for hydraulic pumping.
Hydraulic Pump Motor Sizing
Motor size vs. flow rate, shaft torque, shaft power and hydraulic power.
Hydraulic Pump Volume Capacity
Calculate hydraulic pump volume capacity.
