Hydraulic Pump Volume Capacity
Hydraulic pump capacity can be estimated in Imperial units as
q = 0.26 A s / t                                         (1)
q = pump output capacity (gpm)
A = area of cylinder (in2)
s = piston stroke (in)
t = required time for full stroke (s)
  • 1 gpm (US) =6.30888x10-5 m3/s = 0.227 m3/h = 0.06309 dm3(litre)/s = 2.228x10-3 ft3/s = 0.1337 ft3/min = 0.8327 gpm (UK)
  • 1 in (inch) = 25.4 mm = 2.54 cm = 0.0254 m = 0.08333 ft
  • 1 in2 = 6.452 cm2 = 6.452x10-4 m2 = 6.944x10-3 ft2
Hydraulic pump capacity can be estimated in Metric units as
q = 10-6 A s / t                                         (2)
q = pump output capacity (l/s)
A = area of cylinder (mm2)
s = piston stroke (mm)
Required pump output for hydraulic cylinders ranging 1 - 6 1/2 inches are indicated below. Multiply pump capacity with stroke length (in).
Example - Required Pump Capacity
A 3" hydraulic cylinder with cylinder area 7.065 in2 makes a 30 inches stroke in 3 seconds. The required pump capacity can be calculated
 q = 0.26 (7.065 in2) (30 in) / (3 s)
    = 18.4 gpm
Hydraulic Pump Volume Capacity Calculator
Imperial Units
SI Units
Hydraulics and Pneumatics
Hydraulic and pneumatic systems - fluids, forces, pumps and pistons.
Hydraulic Cylinder Area vs. Diameter
Typical hydraulic cylinders and acting area vs. cylinder diameter.
Hydraulic Cylinders - Volume Displacement
The volumetric displacement of hydraulic cylinders.
Hydraulic Force vs. Pressure and Cylinder Size
Calculate hydraulic cylinder force.
Hydraulic Oil Pump - Horsepower vs. Pressure and Volume Flow
The power required for hydraulic pumping.
Hydraulic Pump Motor Sizing
Motor size vs. flow rate, shaft torque, shaft power and hydraulic power.
