When a bolt is lubricated - less torque is required to achieve bolt axial load or tension. Reduction of torques for lubricated vs. dry bolts are indicated in the table below.
Lubricant | Torque Reduction (%) |
Graphite | 50 - 55 |
White Grease | 35 - 45 |
SAE 30 oil | 35 - 45 |
SAE 40 oil | 30 - 40 |
No lube | 0 |
Example - Reduction of Torque when Bolt is Lubricated
The maximum tightening torque for a slightly lubricated 1" Grade 5 coarse bolt is 483 lbf ft. Dry bolt torque is approximately 30% higher - or 628 lbf ft.
Tdry = (483 lbf ft) (1 + (30%) / (100%))
= 628 lbf ft
If the bolt is lubricated with SAE 30 oil - the torque compared to a dry bolt is reduced with approximately 40%.
TSAE30 = (628 lbf ft) (1 - (40%) / (100%))
= 377 lbf ft
Note that if torque specified for a dry or slightly oiled bolt torque is applied to a lubricated bolt - the bolt may overload and break.
• Fasteners
Bolt Torque Calculator: Loads & Preloads Data and Calculator
Calculate required bolt torque.
Cast Iron Flanges - Stud Reference Chart
The number, diameter and length of studs for cast iron flanges class 125 and 250.
Grease - Temperature Limits
Temperature limits for grease - a combination of oil and thickener.
Improvised Torque Wrench
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
ISO 28741 Metric Thread Dimensions for Spark Plugs
Metric threads spark plugs according ISO 28741.
ISO 724 - Metric Threads
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Oil Lubrication - Temperature Limits
Temperature limits for lubricating oils.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Torque Specifications for Metric Bolts: Maximum Values & Tables
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
U.S. Bolts - Tightening Torques
Recommended bolt torques.
U.S. Bolts: Tensile Strength & Proof Load Specifications
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
US Machine Screws - Dimensions
Machine screw diameters.
Whitworth Bolt Torques
Torque specifications Whitworth bolts.
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
