ASME/ANSI B18.2.3.1M Metric Hex Cap Screws
Calculate required bolt torque.
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
ANSI/SO, DIN and JIS bolts.
Metric versus Imperial equivalent screw dimensions.
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
Recommended bolt torques.
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
