Nominal Pipe Size NPS (inches) | Class 300 | ||||
Diameter of Flange (inches) | No. of Bolts | Diameter of Bolts (inches) | Diameter of Bolt Holes (inches) | Bolt Circle (inches) | |
1/4 | 3-3/8 | 4 | 1/2 | 0.62 | 2-1/4 |
1/2 | 3-3/4 | 4 | 1/2 | 0.62 | 2-5/8 |
3/4 | 4-5/8 | 4 | 5/8 | 0.75 | 3-1/4 |
1 | 4-7/8 | 4 | 5/8 | 0.75 | 3-1/2 |
1-1/4 | 5-1/4 | 4 | 5/8 | 0.75 | 3-7/8 |
1-1/2 | 6-1/8 | 4 | 3/4 | 0.88 | 4-1/2 |
2 | 6-1/2 | 8 | 5/8 | 0.75 | 5 |
2-1/2 | 7-1/2 | 8 | 3/4 | 0.88 | 5-7/8 |
3 | 8-1/4 | 8 | 3/4 | 0.88 | 6-5/8 |
3-1/2 | 9 | 8 | 3/4 | 0.88 | 7-1/4 |
4 | 10 | 8 | 3/4 | 0.88 | 7-7/8 |
5 | 11 | 8 | 3/4 | 0.88 | 9-1/4 |
6 | 12-1/2 | 12 | 3/4 | 0.88 | 10-5/8 |
8 | 15 | 12 | 7/8 | 1 | 13 |
10 | 17-1/2 | 16 | 1 | 1.12 | 15-1/4 |
12 | 20-1/2 | 16 | 1-1/8 | 1.25 | 17-3/4 |
14 | 23 | 20 | 1-1/8 | 1.25 | 20-1/4 |
16 | 25-1/2 | 20 | 1-1/4 | 1.38 | 22-1/2 |
18 | 28 | 24 | 1-1/4 | 1.38 | 24-3/4 |
20 | 30-1/2 | 24 | 1-1/4 | 1.38 | 27 |
24 | 36 | 24 | 1-1/2 | 1.62 | 32 |
Nominal Pipe Size NPS (inches) | Class 400 | ||||
3-1/2 | 9 | 8 | 7/8 | 1 | 7-1/4 |
4 | 10 | 8 | 7/8 | 1 | 7-7/8 |
5 | 11 | 8 | 7/8 | 1 | 9-1/4 |
6 | 12-1/2 | 12 | 7/8 | 1 | 10-5/8 |
8 | 15 | 12 | 1 | 1.12 | 13 |
10 | 17-1/2 | 16 | 1-1/8 | 1.25 | 15-1/4 |
12 | 20-1/2 | 16 | 1-1/4 | 1.38 | 17-3/4 |
14 | 23 | 20 | 1-1/4 | 1.38 | 20-1/4 |
16 | 25-1/2 | 20 | 1-3/8 | 1.5 | 22-1/2 |
18 | 28 | 24 | 1-3/8 | 1.5 | 24-3/4 |
20 | 30-1/2 | 24 | 1-1/2 | 1.62 | 27 |
24 | 36 | 24 | 1-3/4 | 1.88 | 32 |
Nominal Pipe Size NPS (inches) | Class 600 | ||||
4 | 10-3/4 | 8 | 7/8 | 1 | 8-1/2 |
5 | 13 | 8 | 1 | 1.12 | 10-1/2 |
6 | 14 | 12 | 1 | 1.12 | 11-1/2 |
8 | 16-1/2 | 12 | 1-1/8 | 1.25 | 13-3/4 |
10 | 20 | 16 | 1-1/4 | 1.38 | 17 |
12 | 22 | 20 | 1-1/4 | 1.38 | 19-1/4 |
14 | 23-3/4 | 20 | 1-3/8 | 1.5 | 20-3/4 |
16 | 27 | 20 | 1-1/2 | 1.62 | 23-3/4 |
18 | 29-1/4 | 20 | 1-5/8 | 1.75 | 25-3/4 |
20 | 32 | 24 | 1-5/8 | 1.75 | 28-1/2 |
24 | 37 | 24 | 1-7/8 | 2 | 33 |
Nominal Pipe Size NPS (inches) | Class 900 | ||||
1/2 | 4-3/4 | 4 | 3/4 | 0.88 | 3-1/4 |
3/4 | 5-1/8 | 4 | 3/4 | 0.88 | 3-1/2 |
1 | 5-7/8 | 4 | 7/8 | 1 | 4 |
1-1/4 | 6-1/4 | 4 | 7/8 | 1 | 4-3/8 |
1-1/2 | 7 | 4 | 1 | 1.12 | 4-7/8 |
2 | 8-1/2 | 8 | 7/8 | 1 | 6-1/2 |
2-1/2 | 9-5/8 | 8 | 1 | 1.12 | 7-1/2 |
3 | 9-1/2 | 8 | 7/8 | 1 | 7-1/2 |
4 | 11-1/2 | 8 | 1-1/8 | 1.25 | 9-1/4 |
5 | 13-3/4 | 8 | 1-1/4 | 1.38 | 11 |
6 | 15 | 12 | 1-1/8 | 1.25 | 12-1/2 |
8 | 18-1/2 | 12 | 1-3/8 | 1.5 | 15-1/2 |
10 | 21-1/2 | 16 | 1-3/8 | 1.5 | 18-1/2 |
12 | 24 | 20 | 1-3/8 | 1.5 | 21 |
14 | 25-1/4 | 20 | 1-1/2 | 1.62 | 22 |
16 | 27-3/4 | 20 | 1-5/8 | 1.75 | 24-1/2 |
18 | 31 | 20 | 1-7/8 | 2 | 27 |
20 | 33-3/4 | 20 | 2 | 2.12 | 29-1/2 |
24 | 41 | 20 | 2-1/2 | 2.62 | 35-1/2 |
Nominal Pipe Size NPS (inches) | Class 1500 | ||||
3 | 10-1/2 | 8 | 1-1/8 | 1.25 | 8 |
4 | 12-1/4 | 8 | 1-1/4 | 1.38 | 9-1/2 |
5 | 14-3/4 | 8 | 1-1/2 | 1.62 | 11-1/2 |
6 | 15-1/2 | 12 | 1-3/8 | 1.5 | 12-1/2 |
8 | 19 | 12 | 1-5/8 | 1.75 | 15-1/2 |
10 | 23 | 12 | 1-7/8 | 2 | 19 |
12 | 26-1/2 | 16 | 2 | 2.12 | 22-1/2 |
14 | 29-1/2 | 16 | 2-1/4 | 2.38 | 25 |
16 | 32-1/2 | 16 | 2-1/2 | 2.62 | 27-3/4 |
18 | 36 | 16 | 2-3/4 | 2.88 | 30-1/2 |
20 | 38-3/4 | 16 | 3 | 3.12 | 32-3/4 |
24 | 46 | 16 | 3-1/2 | 3.62 | 39 |
Nominal Pipe Size NPS (inches) | Class 2500 | ||||
1/2 | 5-1/4 | 4 | 3/4 | 0.88 | 3-1/2 |
3/4 | 5-1/2 | 4 | 3/4 | 0.88 | 3-3/4 |
1 | 6-1/4 | 4 | 7/8 | 1 | 4-1/4 |
1-1/4 | 7-1/4 | 4 | 1 | 1.12 | 5-1/8 |
1-1/2 | 8 | 4 | 1-1/8 | 1.25 | 5-3/4 |
2 | 9-1/4 | 8 | 1 | 1.12 | 6-3/4 |
2-1/2 | 10-1/2 | 8 | 1-1/8 | 1.25 | 7-3/4 |
3 | 12 | 8 | 1-1/4 | 1.38 | 9 |
4 | 14 | 8 | 1-1/2 | 1.62 | 10-3/4 |
5 | 16-1/2 | 8 | 1-3/4 | 1.88 | 12-3/4 |
6 | 19 | 8 | 2 | 2.12 | 14-1/2 |
8 | 21-3/4 | 12 | 2 | 2.12 | 17-1/4 |
10 | 26-1/2 | 12 | 2-1/2 | 2.62 | 21-1/4 |
12 | 30 | 12 | 2-3/4 | 2.88 | 24-3/8 |
Insert flanges to your Sketchup model with the Engineering ToolBox Sketchup Extension
ASME is one of the leading organizations in the world developing codes and standards.
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
Convert between US Inches and metric mm wrench and spanner sizes.
