For metric bolts strength is according ISO 898 Mechanical properties of fasteners made of carbon steel and alloy steel described by "property classes" with designations 4.6, 4.8, 5.8, 8.8, 9.8, 10.9 and 12.9.
Property ClassHead MarkingSize Range
(mm)
Minimum Proof Strength
(106 Pa)
Minimum Tensile Strength
(106 Pa)
Material
4.6 M5 - M36 225 400 Low or medium carbon steel
4.8 M1.6 - M16 310 420 Low or medium carbon steel
5.8 M5 - M24 380 520 Low or medium carbon steel
8.8 M1.6 - M36 600 830 Medium carbon steel, Q & T
9.8 M1.6 - M16 650 900 Medium carbon steel, Q & T
10.9 M5 - M36 830 1040 Low carbon martensite steel, Q & T
12.9 M1.6 - M36 970 1220 Alloy steel, Q & T
  • 1 Pa = 1 N/m2 = 1.4504×10-4 lb/in2 (psi)
Fasteners
Mechanics
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Flanges - API vs. ASME/ANSI
API and ASME/ANSI flanges - comparing dimensions and pressure ratings.
Forged Steel Flanges - Stud Charts
Number of studs, diameter and length for ANSI forged steel flanges ranging class 150 to 1500.
ISO 724 - Metric Threads
Japanese industrial flanges, bolts, nuts, and gaskets standards and specifications from JAS - the Japanese Standards Association.
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Steel Pipe Flanges for Waterworks Services
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Torque Specifications for Metric Bolts: Maximum Values & Tables
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
U.S. Bolts - Tightening Torques
Recommended bolt torques.
U.S. Bolts: Tensile Strength & Proof Load Specifications
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
US Machine Screws - Dimensions
Machine screw diameters.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
