Flanges - API vs. ASME/ANSI
Although the dimensions of ASME and API flanges may sometimes be compatible for bolting - using the same bolt circle and the same number of bolts - they do not share the same pressure rating system.
- ASME rates the pressure of a class based on the material of construction and the design temperature
- API specifies allowable materials and gives it a specific pressure rating
The difference between ASME/ANSI and API is the fabrication material and a higher rated API operating pressure.
ASME/ANSI flanges are commonly used in industrial process systems handling water, steam, air and gas. API flanges are manufactured for high strength operating refinery systems with products such as oil and explosive gases.
The flange standards API 6A and ASME/ANSI B16.5 have the same dimensions - but the API 6A flanges are rated for higher pressures as indicated below:
Flange | Pressure Class Rating (psi) | Nominal Size Range (inches) | ||
ASME/ANSI B16.5 | API 6A | ASME/ANSI B16.5 | API 6A1) | |
Weld neck | 600 | 2000 | 1/2 - 24 | 113/16 - 11 |
900 | 3000 | |||
1500 | 5000 | |||
Blind and Threaded | 600 | 2000 | 113/16 - 211/4 | |
900 | 3000 | 113/16 - 203/4 | ||
1500 | 5000 | 113/16 - 11 |
1) In the old API standard, flanges ranged from 1 1/2 to 10(20) inches.
- 1 inch = 25.4 mm
• Piping Codes and Standards
API - American Petroleum Institute
The American Petroleum Institute - API.
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 1500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 1500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
Gasket Characteristics
Gaskets are used to make a fluid or gas resistant seal between two surfaces.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Steel Pipe Flanges for Waterworks Services
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
