Analytical Detection and Quantification Limits: Survey of State and Federal Approaches
National and International organizations producing codes and standards - ANSI, ISO, DIN, BSi and more.
An overview of the American Petroleum Institute - API - valve standards.
Temperature and pressure ratings for valves according API 6D.
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
API and ASME/ANSI flanges - comparing dimensions and pressure ratings.
