Industrial flanges, bolts, nuts, and gaskets standards and specifications from the Japanese Standards Association - JAS: ordered by divisions:
B. Mechanical Engineering
- JIS B 1189:1999
Hexagon flange bolt - JIS B 1190:1999
Hexagon nuts with flange - JIS B 1451:1991
Rigid flanged shaft couplings - JIS B 1452:1991
Flexible flanged shaft couplings - JIS B 2205:1991
Basis for calculation of pipe flanges - JIS B 2206:1995
Basis for calculation of aluminum alloy pipe flanges - JIS B 2207:1995
Basis for calculation of aluminum alloy pipe flanges with full face gasket - JIS B 2220:2004
Steel pipe flanges - JIS B 2239:2004
Cast iron pipe flanges - JIS B 2240:1996
General rules for copper alloy pipe flanges - JIS B 2241:1986
Basic dimensions of aluminum alloy pipe flanges - JIS B 2290:1998
Vacuum technology -- Flange dimensions - JIS B 2291:1994
21 MPa slip-on welding pipe flanges for hydraulic use - JIS B 2292-1/2/3:2000
Hydraulic fluid power -- Positive displacement pumps and motors -- Dimensions and identification code for mounting flanges and shaft ends --
Part 1: Inch series shown in metric units
Part 2: Two-and four-hole flanges and shaft ends -- Metric series
Part 3: Polygonal flanges (including circular flanges) - JIS B 2404:1999
Dimensions of gaskets for use with pipe flanges - JIS B 8436:1996
Manipulating industrial robots -- Mechanical flanges interfaces -- Part 1: Plates (form A) - JIS B 8602:2002
Pipe flanges for refrigerants
D. Automotive Engineering
- JIS D 3631:1998
Road vehicles -- Shapes and dimensions of fuel injection nozzle holders for diesel engines -- Size "S" - JIS D 3701:1987
Dimensions of carburetor flanges for automobiles
F. Shipbuilding
- JIS F 7381:1996
Shipbuilding -- Bronze 5K flanged cocks - JIS F 7804:2000
Shipbuilding -- 5K copper alloy pipe flanges for marine use - JIS F 7805:1976
Basic dimensions of steel flanges for marine exhaust gas pipe - JIS F 7806:1996
Shipbuilding -- Ships' 280K and 350K socket welding pipe flanges - JIS F 0602:1995
Shipbuilding -- Non-asbestos gaskets to cargo piping system -- Application standard - JIS F 7102:1997
Shipbuilding -- Piping system in machinery space -- Application for gaskets and packings
G. Ferrous Materials and Metallurgy
- JIS G 3223:1988
High tensile strength steel forgings for tower flanges
Z. Miscellaneous, Packaging, Welding, Radioactivity, etc.
- JIS Z 1604:1995
Plugs and flanges for steel drums
• International Valve Standards
International valve standards for piping systems.
• Piping Codes and Standards
Gasket Characteristics
Gaskets are used to make a fluid or gas resistant seal between two surfaces.
Gaskets - Temperature Ratings
Temperature ratings for gaskets materials.
JIS - Japanese Industrial Standards
Japanese Standards Association - JSA.
JIS - Pipe, Tube and Fittings Standards
Japanese industrial pipe, tube and fittings standards and specifications from the Japanese Standards Association - JAS.
JIS - Valve Standards
Japanese industrial valve standards and specifications from JAS - the Japanese Standards Association.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Steel Pipe Flanges for Waterworks Services
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
