The number, diameter and length of studs for cast iron flanges class 125 and 250.
ANSI/SO, DIN and JIS bolts.
Metric versus Imperial equivalent screw dimensions.
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
Machine screw diameters.
Convert between US Inches and metric mm wrench and spanner sizes.
