Oil Lubrication - Temperature Limits
Typical temperature limits for lubricating oils:
OilTemperature Limits
(oF)(oC)
Mineral 300 149
Petroleum 300 149
Petroleum, superrefined 350 149
Perfluorinated compounds 600 316
Polyphenolether 500 260
Silicones 500 260
Synthetic esters 400 204
Synthetic hydrocarbon 400 204
Miscellaneous
Flash Points - Liquids
The flash points for some common liquids and fuels.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Viscosities and densities of SAE Grade oils.
