Tabulated values and viscosity units conversion are given below the figures.
Oxygen phase diagram
Online Oxygen Viscosity Calculator
The calculator below can be used to estimate oxygen dynamic or kinematic viscosity at given temperatures and atmospheric pressure.
The output dynamic viscosity is given as Pas, Ns/m2, cP, mPas, lbfs/ft2 and lbm/fth, while the kinematic viscosity is given as cSt, m2/s and ft2/s.
See also other properties of Oxygen at varying temperature and pressure: Density and specific weight and Specific heat (heat capacity), and Thermophysical properties at standard conditions,
as well as dynamic and kinematic viscosity of air, ammonia, benzene, butane, carbon dioxide, ethane, ethanol, ethylene, methane, methanol, nitrogen, propane and water.
Oxygen dynamic and kinematic viscosity at atmospheric pressure and varying temperature:
Dynamic viscosity of oxygen at varying temperature and 1, 10, 50 and 100 bara (14.5, 145, 725 and 1450 psia):
Dynamic viscosity of oxygen at gas-liquid equilibrium pressure:
Kinematic viscosity of oxygen at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of oxygen at given temperatures and pressures, SI and Imperial units:
State Temperature Pressure Dynamic (Absolute) Viscosity Kinematic Viscosity
(K) (°C) (°F) (bara) (psia) (μPa s) (cP) ( ×10-6 lbf s/ft2) ( ×10-6 lbm s/ft s) (lbm/ft h) (cSt),
( ×10-6 m2/s)
( ×10-6 ft2/s)
Liquid at
equilibrium
54.361 -218.79 -361.82 0.0015 0.0212 773.62 0.7736 16.16 519.8 1.871 0.5923 6.376
70 -203 -334 0.0626 0.908 371.79 0.3718 7.765 249.8 0.8994 0.3006 3.235
75 -198 -325 0.145 2.11 308.66 0.3087 6.446 207.4 0.7467 0.2543 2.737
80 -193 -316 0.301 4.37 261.22 0.2612 5.456 175.5 0.6319 0.2194 2.362
90 -183 -298 0.994 14.4 195.64 0.1956 4.086 131.5 0.4733 0.1713 1.844
100 -173 -280 2.54 36.8 152.56 0.1526 3.186 102.5 0.3691 0.1398 1.505
110 -163 -262 5.43 78.8 121.52 0.1215 2.538 81.66 0.2940 0.1174 1.263
120 -153 -244 10.2 148.3 97.43 0.09743 2.035 65.47 0.2357 0.1000 1.077
130 -143 -226 17.5 253.7 77.57 0.07757 1.620 52.13 0.1877 0.08595 0.9252
140 -133 -208 27.9 404.3 60.22 0.06022 1.258 40.47 0.1457 0.07405 0.7971
145 -128 -199 34.5 500.0 51.87 0.05187 1.083 34.85 0.1255 0.06869 0.7393
150 -123 -190 42.2 611.9 42.90 0.04290 0.8960 28.83 0.1038 0.06351 0.6836
Gas at
equilibrium
54.361 -218.79 -361.82 0.0015 0.0212 4.096 0.00410 0.08555 2.753 0.00991 395.4 4257
70 -203 -334 0.0626 0.908 5.356 0.0053557 0.1119 3.599 0.01296 15.49 166.7
75 -198 -325 0.145 2.11 5.753 0.0057533 0.1202 3.866 0.01392 7.648 82.32
80 -193 -316 0.301 4.37 6.149 0.0061486 0.1284 4.132 0.01487 4.187 45.07
90 -183 -298 0.994 14.4 6.936 0.0069355 0.1449 4.660 0.01678 1.581 17.02
100 -173 -280 2.54 36.8 7.728 0.0077281 0.1614 5.193 0.01869 0.7413 7.979
110 -163 -262 5.43 78.8 8.547 0.0085467 0.1785 5.743 0.02068 0.4016 4.323
120 -153 -244 10.2 148.3 9.427 0.0094273 0.1969 6.335 0.02281 0.2398 2.581
130 -143 -226 17.5 253.7 10.45 0.01045 0.2181 7.019 0.02527 0.1528 1.644
140 -133 -208 27.9 404.3 11.82 0.01182 0.2469 7.945 0.02860 0.1013 1.090
145 -128 -199 34.5 500.0 12.88 0.01288 0.2690 8.656 0.03116 0.08315 0.8950
150 -123 -190 42.2 611.9 14.72 0.01472 0.3075 9.892 0.03561 0.06849 0.7372
Liquid 54.37 -218.8 -361.8 1 14.5 773.8 0.7738 16.16 520.0 1.872 0.5925 6.378
60 -213 -352 1 14.5 578.5 0.5785 12.08 388.7 1.399 0.4512 4.857
80 -193 -316 1 14.5 261.4 0.2614 5.459 175.7 0.6323 0.2195 2.362
90.06 -183.09 -297.56 1 14.5 195.3 0.1953 4.079 131.2 0.4724 0.1710 1.841
Gas
90.06 -183.09 -297.56 1 14.5 6.940 0.00694 0.1449 4.663 0.01679 1.573 16.93
100 -173 -280 1 14.5 7.712 0.007712 0.1611 5.182 0.01866 1.957 21.06
120 -153 -244 1 14.5 9.219 0.009219 0.1925 6.195 0.02230 2.835 30.51
140 -133 -208 1 14.5 10.67 0.01067 0.2228 7.170 0.02581 3.846 41.40
160 -113 -172 1 14.5 12.07 0.01207 0.2521 8.111 0.02920 4.988 53.69
180 -93.2 -136 1 14.5 13.41 0.01341 0.2801 9.011 0.03244 6.246 67.23
200 -73.2 -99.7 1 14.5 14.72 0.01472 0.3074 9.891 0.03561 7.627 82.10
220 -53.2 -63.7 1 14.5 15.98 0.01598 0.3337 10.74 0.03866 9.116 98.12
240 -33.2 -27.7 1 14.5 17.20 0.01720 0.3592 11.56 0.04161 10.71 115.3
260 -13.2 8.3 1 14.5 18.38 0.01838 0.3839 12.35 0.04446 12.40 133.5
280 6.9 44.3 1 14.5 19.53 0.01953 0.4079 13.12 0.04724 14.19 152.8
300 26.9 80.3 1 14.5 20.65 0.02065 0.4313 13.88 0.04995 16.08 173.1
320 46.9 116 1 14.5 21.74 0.02174 0.4540 14.61 0.05259 18.07 194.5
340 66.9 152 1 14.5 22.80 0.02280 0.4762 15.32 0.05516 20.14 216.8
360 86.9 188 1 14.5 23.84 0.02384 0.4979 16.02 0.05767 22.30 240.0
400 127 260 1 14.5 25.84 0.02584 0.5397 17.36 0.06251 26.86 289.1
500 227 440 1 14.5 30.49 0.03049 0.6368 20.49 0.07376 39.62 426.4
600 327 620 1 14.5 34.73 0.03473 0.7254 23.34 0.08401 54.16 582.9
700 427 800 1 14.5 38.65 0.03865 0.8072 25.97 0.09350 70.31 756.8
800 527 980 1 14.5 42.33 0.04233 0.8841 28.44 0.1024 88.02 947.5
900 627 1160 1 14.5 45.81 0.04581 0.9568 30.78 0.1108 107.2 1153.4
1000 727 1340 1 14.5 49.12 0.04912 1.026 33.01 0.1188 127.7 1374.0
Liquid 54.47 -218.68 -361.62 10 145 775.0 0.7750 16.19 520.8 1.875 0.5930 6.383
60 -213 -352 10 145 582.7 0.5827 12.17 391.6 1.410 0.4542 4.889
80 -193 -316 10 145 263.6 0.2636 5.505 177.1 0.6377 0.2211 2.380
100 -173 -280 10 145 153.9 0.1539 3.214 103.4 0.3723 0.1408 1.516
119.62 -153.53 -244.35 10 145 98.25 0.09825 2.052 66.02 0.2377 0.1006 1.083
Gas 119.62 -153.53 -244.35 10 145 9.392 0.009392 0.1962 6.311 0.02272 0.2442 2.629
120 -153 -244 10 145 9.421 0.009421 0.1968 6.331 0.02279 0.2463 2.651
140 -133 -208 10 145 10.89 0.01089 0.2274 7.318 0.02634 0.3583 3.857
160 -113 -172 10 145 12.29 0.01229 0.2567 8.258 0.02973 0.4791 5.157
180 -93.2 -136 10 145 13.64 0.01364 0.2849 9.166 0.03300 0.6108 6.575
200 -73.2 -99.7 10 145 14.94 0.01494 0.3120 10.04 0.03614 0.7530 8.105
220 -53.2 -63.7 10 145 16.20 0.01620 0.3383 10.89 0.03919 0.9060 9.753
240 -33.2 -27.7 10 145 17.41 0.01741 0.3636 11.70 0.04212 1.068 11.50
260 -13.2 8.3 10 145 18.59 0.01859 0.3883 12.49 0.04497 1.241 13.36
280 6.9 44.3 10 145 19.73 0.01973 0.4121 13.26 0.04773 1.424 15.32
300 26.9 80.3 10 145 20.85 0.02085 0.4355 14.01 0.05044 1.615 17.38
320 46.9 116 10 145 21.93 0.02193 0.4580 14.74 0.05305 1.815 19.54
340 66.9 152 10 145 22.99 0.02299 0.4802 15.45 0.05561 2.026 21.80
360 86.9 188 10 145 24.02 0.02402 0.5017 16.14 0.05811 2.243 24.14
400 127 260 10 145 26.01 0.02601 0.5432 17.48 0.06292 2.703 29.09
500 226.85 440.33 10 145 30.63 0.03063 0.6397 20.58 0.07410 3.987 42.91
600 327 620 10 145 34.80 0.03480 0.7268 23.38 0.08418 5.439 58.55
700 427 800 10 145 38.77 0.03877 0.8096 26.05 0.09378 7.070 76.10
800 527 980 10 145 42.43 0.04243 0.8862 28.51 0.1026 8.843 95.19
900 627 1160 10 145 45.90 0.04590 0.9586 30.84 0.1110 10.76 115.8
1000 727 1340 10 145 49.20 0.04920 1.028 33.06 0.1190 12.82 137.9
Liquid 100 -173 -280 50 725 160.9 0.1609 3.361 108.1 0.3893 0.1458 1.569
154.36 -118.79 -181.82 50 725 29.67 0.02967 0.6196 19.94 0.07177 0.05791 0.6233
Gas 154.36 -118.79 -181.82 50 725 20.57 0.02057 0.4297 13.83 0.04977 0.05761 0.6201
300 26.9 80.3 50 725 21.77 0.02177 0.4546 14.63 0.05265 0.3299 3.551
500 227 440 50 725 31.27 0.03127 0.6530 21.01 0.07564 0.8205 8.832
700 427 800 50 725 39.26 0.03926 0.8200 26.38 0.09498 1.448 15.59
900 627 1160 50 725 46.31 0.04631 0.9671 31.12 0.1120 2.195 23.62
Liquid 55.5 -217.65 -359.77 100 1450 786.0 0.7860 16.42 528.2 1.901 0.5991 6.448
60 -213 -352 100 1450 625.3 0.6253 13.06 420.2 1.513 0.4832 5.201
80 -193 -316 100 1450 285.2 0.2852 5.957 191.6 0.6899 0.2363 2.543
100 -173 -280 100 1450 169.5 0.1695 3.540 113.9 0.4100 0.1519 1.635
120 -153 -244 100 1450 112.4 0.1124 2.348 75.53 0.2719 0.1107 1.192
140 -133 -208 100 1450 75.70 0.07570 1.581 50.87 0.1831 0.08482 0.9130
160 -113 -172 100 1450 47.96 0.04796 1.002 32.23 0.1160 0.06698 0.7210
Supercritical
phase
180 -93.2 -136 100 1450 26.07 0.02607 0.5445 17.52 0.06307 0.06159 0.6629
200 -73.2 -99.7 100 1450 20.74 0.02074 0.4332 13.94 0.05017 0.07471 0.8042
220 -53.2 -63.7 100 1450 20.24 0.02024 0.4227 13.60 0.04896 0.09204 0.991
240 -33.2 -27.7 100 1450 20.67 0.02067 0.4317 13.89 0.05000 0.1107 1.192
260 -13.2 8.3 100 1450 21.40 0.02140 0.4469 14.38 0.05177 0.1303 1.403
280 6.9 44.3 100 1450 22.25 0.02225 0.4647 14.95 0.05382 0.1507 1.623
300 26.9 80.3 100 1450 23.15 0.02315 0.4835 15.56 0.05600 0.1720 1.851
320 46.9 116 100 1450 24.07 0.02407 0.5027 16.17 0.05823 0.1941 2.089
340 66.9 152 100 1450 25.00 0.02500 0.5221 16.80 0.06048 0.2170 2.336
360 86.9 188 100 1450 25.92 0.02592 0.5414 17.42 0.06270 0.2404 2.588
400 127 260 100 1450 27.74 0.02774 0.5794 18.64 0.06711 0.2900 3.121
500 227 440 100 1450 32.07 0.03207 0.6698 21.55 0.07758 0.4258 4.583
600 327 620 100 1450 36.10 0.03610 0.7540 24.26 0.08733 0.5782 6.223
700 427 800 100 1450 39.87 0.03987 0.8327 26.79 0.09645 0.7458 8.028
800 527 980 100 1450 43.43 0.04343 0.9071 29.18 0.1051 0.9282 9.991
900 627 1160 100 1450 46.80 0.04680 0.9774 31.45 0.1132 1.124 12.10
1000 727 1340 100 1450 50.03 0.05003 1.045 33.62 0.1210 1.334 14.36
Liquid 100 -173 -280 250 3626 194.4 0.1944 4.060 130.6 0.4702 0.1693 1.822
Supercritical
phase
300 26.9 80.3 250 3626 29.61 0.02961 0.6183 19.89 0.07162 0.08902 0.9582
500 227 440 250 3626 34.71 0.03471 0.7248 23.32 0.08395 0.1928 2.076
700 427 800 250 3626 41.71 0.04171 0.8712 28.03 0.1009 0.3265 3.515
900 627 1160 250 3626 48.27 0.04827 1.008 32.44 0.1168 0.4831 5.201
Liquid 100 -173 -280 750 10878 275.0 0.2750 5.743 184.8 0.6652 0.2246 2.417
Supercritical
phase
300 26.9 80.3 750 10878 53.38 0.05338 1.115 35.87 0.1291 0.07721 0.8311
500 227 440 750 10878 45.08 0.04508 0.9416 30.30 0.1091 0.1024 1.102
700 427 800 750 10878 48.27 0.04827 1.008 32.44 0.1168 0.1479 1.592
900 627 1160 750 10878 53.16 0.05316 1.110 35.72 0.1286 0.2032 2.187
Unit conversion:
Viscosity, Dynamic (Absolute)
centipoise (cP), gram/(centimeter second) (g/(cm s)) = poise (P),  kilogram/meter second (kg/m s)=newton second/square meter (N s/m2)= pascal second (Pa s), pound/(foot hour) (lb/(ft h)), pound/(foot second) (lb/(ft s)), reyn (reyn)
  • 1 cP = 0.001 Pa s = 0.01 P = 0.01 g/(cm sec) = 6.72197×10-4 lb/(ft s) = 2.4191 lb/(ft h)
  • 1 kg/(m s) = 1 (N s)/m2= 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 (N s)/m2= 1 kg/(m s) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 reyn = 6894.76 Pa s
Viscosity, Kinematic
centistoke (cSt) = square millimeter/second (mm2/s), square foot/hour (ft2/h), square foot/second (ft2/s), square inch/second (in2/s), square meter/hour (m2/h), square meter/second (m2/s), stoke (St) = square centimeter/second (cm2/s)
  • 1 cm2/s = 1 St = 100 mm2/s = 100 cSt = 1×10-4 m2/s = 0.36 m2/h = 1.07639×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
  • 1 cSt = 1 mm2/s = 0.01 St = 1×10-6 m2/s = 0.0036 m2/h = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 ft2/h = 2.7778×10-4 ft2/s = 0.04 in2/s = 2.58064×10-5m2/s = 0.09290304 m2/h = 25.8064 cS = 0.258064 St
  • 1 m2/h = 1/3600 m2/s = 2.7778×10-4 m2/s = 2.7778 cm2/s = 277.78 mm2/s = 277.78 cSt = 2.7778 St = 0.00298998 ft2/s = 10.7639 ft2/h = 0.430556 in2/s
  • 1 m2/s = 3600 m2/h = 1×104 cm2/s = 1×104 St = 1×106 mm2/s = 1×106 cSt = 10.7639 ft2/s = 38750.08 ft2/h = 1550003 in2/s
  • 1 mm2/s = 1 cSt = 1×10-6 m2/s = 0.0036 m2/h = 0.01 cm2/s = 0.01 St = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 St = 1 cm2/s = 100 cSt = 100 mm2/s = 1×10-4 m2/s = 0.36 m2/h = 1.076×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
Fluid Mechanics
Material Properties
Thermodynamics
Viscosities
Carbon Dioxide - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
