Solubility of pure gases like
- Ar - Argon
- CH4 - Methane
- C2H4 - Ethylene
- C2H6- Ethane
- CO - Carbon Monoxide
- CO2 - Carbon Dioxide
- Cl2 - Chlorine Gas
- H2 - Hydrogen Gas
- H2S - Hydrogen Sulfide
- He - Helium
- N2 - Nitrogen
- NH3 - Ammonia
- O2 - Oxygen
- SO2 - Sulfur Dioxide
in water at one atmosphere (101.325 kPa) and different temperatures are indicated in the diagrams below.
Note that for gases in combination with other gases - like oxygen in air - the partial pressure of the gas must be used. Example - in air with normal composition oxygen counts for approximate 20% of the total pressure.
Solubility of Ammonia - NH3 - in Water
Solubility of Argon - Ar - in Water
Solubility of Carbon Monoxide - CO - in Water
Solubility of Carbon Dioxide - CO2 - in Water
Solubility of Chlorine Gas - Cl2 - in Water
Solubility of Ethane - C2H6 - in Water
Solubility of Ethylene - C2H4 - in Water
Solubility of Hydrogen Gas - H2 - in Water
Solubility of Hydrogen Sulfide - H2S - in Water
Solubility of Helium - He - in Water
Solubility of Methane - CH4 - in Water
Solubility of Nitrogen - N2 - in Water
Solubility of Oxygen - O2 - in Water
Solubility of Sulfur Dioxide - SO2 - in Water
Argon - Thermophysical Properties
Chemical, Physical and Thermal Properties of Argon.
Boiler Water - Total Dissolved Solids (TDS)
Impurities from the feedwater will concentrate in the boiling water.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Monoxide - CO - Thermophysical Properties
Chemical, Physical and Thermal Properties of Carbon Monoxide - CO.
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Methane (CH₄): Thermophysical Properties and Phase Diagram
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Salinity of Water
Salinity - salt content - of fresh, brackish and sea water.
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Sulfur Dioxide Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
