Helium - Thermophysical Properties
Chemical, physical and thermal properties of Helium - He :
(values at 25 oC (77 oF, 298 K) and atmospheric pressure)
Molecular Weight | 4.0026 |
Specific Gravity, air = 1 | 0.138 |
Specific Volume (ft3/lb, m3/kg) | 97.86, 6.11 |
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) | 7.80, 125 |
Absolute Viscosity (lbm/ft s, centipoises) | 13.4×10-6, 0.02 |
Sound velocity in gas (m/s) | 1015 |
Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) | 1.24, 5188 |
Specific Heat Ratio - cp/cv | 1.66 |
Gas constant - R - (ft lb/lb oR, J/kg oC) | 386, 2077 |
Thermal Conductivity (Btu/hr ft oF, W/moC) | 0.086, 0.149 |
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF,o K) | -452, 4.22 |
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) | 10.0, 23300 |
Critical Temperature (oF,o K) | -450.3, 5.2 |
Critical Pressure (psia, MN/m2) | 33.22, - |
Critical Volume (ft3/lb, m3/kg) | 0.231, 0.0144 |
Flammable | no |
Follow the links below to get values for the listed properties of helium at varying pressure and temperature :
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O .
Carbon Dioxide - Liquid Properties
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Critical Points for some Substances
Critical points of some common substances like air, argon, helium and more
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Density of Gases Data
Gas Mixtures - Properties
Gas mixtures and the ideal gas law, mass calculations, the individual gas constant and density.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Oxygen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of oxygen as an ideal gas.
The Ideal Gas Law
