Oxygen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, Internal Energy and Entropy of Oxygen - O2 - are indicated below.
• Gases and Compressed Air
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
