Heavy water ( deuterium oxide , 2H2O , D2O ) is a form of water that contains a larger than normal amount of the hydrogen isotope deuterium (= heavy hydrogen = 2H = D), rather than the common hydrogen-1 isotope (1H = H = protium) that makes up most of the hydrogen in normal water.
Thermodynamic properties of heavy water - D2O:
  • Boiling temperature (at 101.325 kPa):     101.40 oC = 214.52 °F
  • Bulk modulus elasticity (at 25°C):              2.10×109 Pa or N/m2
  • Critical density:                                         0.356 g/cm3 = 0.691 slug/ft3 = 3.457 lbm/gal(US)
  • Critical pressure :                                      213.88 atm = 220.98 bar = 21.671 MPa (MN/m2) = 3143 psi (=lbf/in2)
  • Critical temperature :                                 370.697 oC = 699.255 °F
  • Ionization constant, pKw (at 25°C):          14.951
  • Latent heat of evaporation (at 101.4°C):  41.521 KJ/mol = 2073.20 kJ/kg = 891.32 Btu(IT)/lb
  • Latent heat of fusion:                               6.132 kJ/mol = 306.2 kJ/kg = 131.64 Btu(IT)/lb
  • Maximum density (at 11.23 oC):               1105.9 kg/m3 = 2.1460 slug/ft3 = 10.74048 lbm/gal(US)
  • Melting temperature (at 101.325 kPa):     3.81 oC = 38.86 °F
  • Molar mass:                                              20.02751 g/mol
  • pD (~pH) (at 25°C):                                  7.43
  • Specific heat (Cp) water (at 20°C):           4.219 kJ/kgK = 1.008 Btu(IT)/(lbm °F) or kcal/(kg K)
  • Specific weight (at 11.23 oC):                   10.8452 kN/m3 = 69.0391 lbf/ft3
  • Surface tension (at 25°C):                       71.87 dyn/cm
  • Triple point pressure:                               0.00652 atm = 0.00661 bar = 661 Pa = 0.0959 psi (=lbf/in2)
  • Triple point temperature:                          3.82 °C = 38.88 °F
  • Vapor pressure (at 25°C):                        20.6 mmHg = 0.027 atm = 0.028 bar = 2750 Pa = 0.398 psi
  • Viscosity (at 20°C):                                   1.251 cP or mPa s
Ionization Constant, pKw , of normal and heavy water with varying temperature.
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene and Water.
Densities
Material Properties
Steam and Condensate
Thermodynamics
Water Systems
Bulk Modulus and Fluid Elasticities
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Heat Capacity
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water Vapor Saturation Pressure: Data, Tables & Calculator
