Ammonia is a colourless gas with a characteristic pungent smell and hazardous in its concentrated form.
Chemical, physical and thermal properties of Ammonia, NH3 :
Values at 25 oC (77 oF, 298 K) and 1 atm, if not other temperature and pressure given.
If values are given for liquid ammonia at ambient temperature, the ammonia is pressurized above 1 atm.
For full table with Imperial units - rotate the screen!
| Property | Value | Unit | Value | Unit | Value | Unit | Value | Unit | |||
| Acidity (pKa) | 9.24 | ||||||||||
| Acidity (pKa) at -33°C | 32.5 | ||||||||||
| Autoignition point | 903 | K | 630 | °C | 1166 | °F | |||||
| Basicity (pKb) | 4.75 | ||||||||||
| Boiling point | 239.82 | K | -33.33 | °C | -27.99 | °F | |||||
| Critical density | 14327 | mol/m3 | 243.99 | kg/m3 | 15.23 | lb/ft3 | 0.4734 | slug/ft3 | |||
| Critical pressure | 11.357 | MPa=MN/m2 | 113.57 | bar | 112.08 | atm | 1647.2 | psi=lbf/in2 | |||
| Critical temperature | 405.56 | K | 132.41 | °C | 270.34 | °F | |||||
| Critical volume | 69.8 | cm3/mol | 0.00410 | m3/kg | 0.0657 | ft3/lb | 2.11 | ft3/slug | |||
| Density, gas | 41.1 | mol/m3 | 0.699 | kg/m3 | 0.0437 | lb/ft3 | 0.00136 | slug/ft3 | |||
| Density, liquid at -28 °F/-33.35°C, 1 atm | 40868 | mol/m3 | 696 | kg/m3 | 43.4 | lb/ft3 | 1.35 | slug/ft3 | |||
| Density, liquid at 70 °F/21.1°C | 36259 | mol/m3 | 617.5 | kg/m3 | 38.55 | lb/ft3 | 1.198 | slug/ft3 | |||
| Flammable | no | ||||||||||
| Flash point | 405 | K | 132 | °C | 269 | °F | |||||
| Gas constant, R | 488.2 | J/kg K | 0.1356 | Wh/(kg K) | 90.74 | ft lbf/lb °R | 2919 | ft lbf/slug °R | |||
| Gibbs free energy of formation, ΔGf | -16.6 | kJ/mol | -975 | kJ/kg | -0.42 | Btu/lb | |||||
| Heat (enthalpy) of combustion, ΔHc (gas) | 382.8 | kJ/mol | 22477 | kJ/kg | 9.663 | Btu/lb | |||||
| Heat (enthalpy) of evaporation, ΔHv, at boiling point | 23.37 | kJ/mol | 1372.0 | kJ/kg | 589.87 | Btu/lb | |||||
| Heat(enthalpy) of formation, ΔHf (gas) | -45.9 | kJ/mol | -2695 | kJ/kg | -1.16 | Btu/lb | |||||
| Heat (enthalpy) of fusion/melting, ΔHm | 5.653 | kJ/mol | 332.3 | kJ/kg | 143 | Btu/lb | |||||
| Heat (enthalpy) of sublimation, ΔHS , at 180 K | 31.2 | kJ/mol | 1832 | kJ/kg | 0.79 | Btu/lb | |||||
| Ionization potential | 10.18 | eV | |||||||||
| Melting (freezing) point | 195.42 | K | -77.73 | °C | -107.91 | °F | |||||
| Molecular Weight | 17.03052 | g/mol | 0.03755 | lb/mol | |||||||
| pH of 0.01 N aqueous solution | 10.6 | ||||||||||
| pH of 0.1 N aqueous solution | 11.1 | ||||||||||
| pH of 1.0 N aqueous solution | 11.6 | ||||||||||
| Standard molar entropy, S° (gas) at 1 bar | 192.77 | J/mol K | 11.32 | kJ/kg K | 0.002704 | Btu/lb °F | |||||
| Solubility in water, at 20°C | 540 | mg/ml | |||||||||
| Solubility in water, at 24°C | 482 | mg/ml | |||||||||
| Sound velocity in gas | 415 | m/s | |||||||||
| Specific Gravity, gas (density relativ to air) | 0.604 | ||||||||||
| Specific heat (heat capacity), Cp (gas) | 37.0 | J/mol K | 2.175 | kJ/kg K | 0.5200 | Btu/lb°F = cal/g K |
| Specific heat (heat capacity), Cp (liquid) | 80.8 | J/mol K | 4.744 | kJ/kg K | 1.133 | Btu/lb°F = cal/g K |
| Specific heat ratio - Cp/Cv (gas) | 1.32 | ||||||||||
| Specific volume | 0.02435 | m3/mol | 1.43 | m3/kg | 22.91 | ft3/lb | 736.99 | ft3/slug | |||
| Surface tension at 11.1°C/52.0°F | 23.4 | dynes/cm | |||||||||
| Surface tension at 34.1°C/93.4°F | 18.1 | dynes/cm | |||||||||
| Thermal Conductivity | 0.026 | W/m°C | 0.015 | Btu/hr ft °F | |||||||
| Triple point pressure | 0.00609 | MPa=MN/m2 | 0.0609 | bar | 0.0601 | atm | 0.883 | psi=lbf/in2 | |||
| Triple point temperature | 195.5 | K | -77.65 | °C | -107.77 | °F | |||||
| Vapor (saturation) pressure | 1.00 | MPa=MN/m2 | 7500 | mm Hg | 9.869 | atm | 145.0 | psi=lbf/in2 | |||
| Vapor (saturation) pressure at -49.72°F/-45.4°C | 0.0533 | MPa=MN/m2 | 400 | mm Hg | 0.526 | atm | 7.73 | psi=lbf/in2 | |||
| Viscosity, dynamic (absolute) (gas) | 0.0100 | cP | 6.72 ×10-6 | lbm/ft s | 0.209 ×10-6 | lbf s/ft2 | |||||
| Viscosity, dynamic (absolute) at 27°C (liq) | 0.1293 | cP | 86.89 ×10-6 | lbm/ft s | 2.70 ×10-6 | lbf s/ft2 | |||||
| Viscosity, dynamic (absolute) at -33.5°C (liq) | 0.255 | cP | 171.4 ×10-6 | lbm/ft s | 5.326 ×10-6 | lbf s/ft2 |
See also the following documents for changes in ammonia properties with changes in pressure and temperature:
- Density at varying temperature and pressure
- Dynamic and Kinematic Viscosity
- Liquid Ammonia - Thermal Properties at Saturation Pressure
- Prandtl number
- Properties at Gas-Liquid Equilibrium Conditions
- Specific heat
- Thermal Conductivity at Varying Temperature and Pressure
- Vapour Pressure at gas-liquid equilibrium
as well as Thermophysical properties of: Acetone, Acetylene, Air, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Ammonia is a gas at standard conditions. However, at low temperature and/or high pressures the gas becomes a liquid. The phase diagram for ammonia shows the phase behavior with changes in temperature and pressure. The curve between the triple point and the critical point shows the ammonia boiling point with changes in pressure.
Below the triple point temperature, ammonia becomes a solid, this phase will also be present at very high pressure (> 10 000 bar) and ambient temperature.
Solubility of Ammonia in Water
• Boiling Points of Fluids
• Densities
• Melting and Freezing Points
• Thermodynamics
• Viscosities
Ammonia and health symptoms - smell and threat to life.
Thermodynamic properties of saturated and superheated ammonia R-717 like specific volume, enthalpy and entropy.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Specific Heat of Common Liquids and Fluids
