The boiling point of a substance is the temperature at which it changes state from liquid to gas throughout the bulk of the liquid. At the boiling point molecules anywhere in the liquid may be vaporized.
The boiling point is defined as the temperature at which the saturated vapor pressure of a liquid is equal to the surrounding atmospheric pressure.
The boiling point at atmospheric pressure (14.7 psia, 1 bar absolute) for some common fluids and gases can be found from the table below:
| Product | Boiling Point at Atmospheric Pressure (oC) |
| Acetaldehyde CH3CHO | 20.8 |
| Acetic acid anhydride (CH3COO)2O | 139 |
| Acetone CH3COCH3 | 56.08 |
| Acentonitrile | 81.6 |
| Acetylene | -84 |
| Acrolein | 52.3 |
| Acrylonitrile | 77.2 |
| Air | -191 |
| Alcohol - ethyl (grain, ethanol) C2H5OH | 79 |
| Alcohol - allyl | 97.2 |
| Alcohol - butyl-n | 117 |
| Alcohol - Isobutyl | 107.8 |
| Alcohol - methyl (methyl alcohol, wood alcohol, wood naphtha or wood spirits) CH3OH | 64.7 |
| Alcohol - propyl | 97.5 |
| Allylamine | 54 |
| Ammonia | -35.5 |
| Aniline | 184.1 |
| Anisole | 153.6 |
| Argon | -186 |
| Benzaldehyde | 178.7 |
| Benzene (Benzol) C6H6 | 80.4 |
| Benzonitrile | 191.1 |
| Blast-furnace gas | -170 |
| Brake Fluid Dot 3 (Dry - Wet boiling points) (Wet includes hygroscopic moisture) | 205 - 140 |
| Brake Fluid Dot 4 (Dry - Wet boiling points) | 230 - 155 |
| Brake Fluid Dot 5 (Dry - Wet boiling points) | 260 - 180 |
| Brake Fluid Dot 5.1 (Dry - Wet boiling points) | 270 - 190 |
| Bromine | 58.8 |
| Bromobenzene | 156.0 |
| 1,2-Butadiene | 10.9 |
| n-Butane | -0.5 |
| 1-Butene | -6.25 |
| Butanal | 74.8 |
| 1-Butanol | 117.6 |
| 2-Butanon | 79.6 |
| Butyric acid n | 162.5 |
| Camphor | 204.0 |
| Carbolic acid (phenol) | 182.2 |
| Carbon bisulfide | 47.8 |
| Carbon dioxide CO2 (sublimates) | -78.5 |
| Carbon disulfide CS2 | 46.2 |
| Carbon monoxide | -192 |
| Carbon tetrachloride (Tetrachloroethane) CCl4 | 76.7 |
| Chlorine | -34.4 |
| Chlorobenzene | 131.7 |
| Chloroform (Trichloromethane) | 62.2 |
| Cyanogen (dicyan) | -21 |
| Cyclohexane | 80.7 |
| Cyclohexanone | 155.4 |
| Cyclopentane | 49.3 |
| n - Decane | 174 |
| Dichlorodifluoromethane (Freon F 12) CCl2F2 | -30 |
| Dichloromethane - see methylene chloride | |
| Diesel fuel | 150 - 360 |
| Diethyl ether | 34.4 |
| Dimethyl sulfate | 186 |
| Dimethyl sulfide | 37.3 |
| Diisopropyl ether | 68.4 |
| 2,2 - Dimethylpentane | 79.2 |
| 1,4-Dioxane | 101.2 |
| Dowtherm | 258 |
| Ethane | -88.78 |
| Ether | 34.6 |
| Ethane C2H6 | -88 |
| Ethanol | 78.24 |
| Ethylamine | 16.6 |
| Ethyl acetate CH3COOC2H3 | 77.2 |
| Ethylbenzene | 136 |
| Ethyl bromide C2H3Br | 38.4 |
| Ethyl chloride | 12 |
| Ethyl ether | 34.5 |
| Ethylene | -103.7 |
| Ethylene bromide | 131.7 |
| Ethylene glycol | 197 |
| 3 - Ethylpentane | 93.5 |
| Fluorine | -187 |
| Formaldehyde | -19.1 |
| Formic acid | 101.0 |
| Trichlorofluoromethane refrigerant R-11 | 23.8 |
| Dichlorodifluoromethane refrigerant R-12 | -29.8 |
| Chlorodifluoromethane refrigerant R-22 | -41.2 |
| 2,3 - Dimethylbutane | 58 |
| Diisobutyl | 109 |
| Furfurol | 161.5 |
| Fuel oil | > 175 |
| Fyrfuryl alcohol | 168 |
| Gasoline, petrol | 38 - 204 |
| Glycerine | 290 |
| Glycol | 197 |
| Helium | -269 |
| n-Heptane | 98.4 |
| n-Hexane | 68.7 |
| Hexylamine | 132 |
| Hydrogen | -253 |
| Hydrochloric acid | -81.7 |
| Hydrofluoric acid | 18.9 |
| Hydrogen chloride | -81.7 |
| Hydrogen sulfide | -60 |
| Iodine | 184.3 |
| Isopropyl alchol | 80.3 |
| Isopropylbenzene hydroperoxide | 153 |
| Isobutane | -11.72 |
| Isobutene | -6.9 |
| Isooctane | 99.2 |
| Isopentane | 27.8 |
| Isoprene | 34.1 |
| Isopropylbenzene | 152 |
| Jet fuel | 163 |
| Kerosene (paraffin) | 150 - 300 |
| Linseed oil | 287 |
| Mercury | 356.9 |
| Methane | -161.5 |
| Methanol (methyl alcohol, wood alcohol) | 64.5 |
| Methyl acetate | 57.2 |
| Methyl bromide | 3.3 |
| Metyl chloride | -23.9 |
| Methylene chloride(CH2Cl2, dichloromethane) | 39.8 |
| Methylamine | -6.4 |
| Methyl ether (C2H6O) | -25 |
| Methylcyclohexane | 101 |
| Methylcyclopentane | 71.8 |
| Methyl iodide | 42.6 |
| 2 - Methylhexane | 90.1 |
| 3 - Methylhexane | 91.8 |
| 2 - Methylpentane | 60.3 |
| 3 - Methylpentane | 63.3 |
| Naphtha | 100 - 160 |
| Naphthalene (Napthaline) | 217.9 |
| Neohexane | 49.7 |
| Neon | -246 |
| Neopentane | 9.5 |
| Nitric acid | 120 |
| Nitrobenzene | 210.9 |
| n - Nonane | 150.7 |
| Nitrogen | -196 |
| n - Octane | 125.6 |
| Olive oil | 300 |
| Oxygen | -183 |
| Paraldehyde | 124 |
| n - Pentane | 36 |
| 1 - Pentene | 30 |
| Peroxyacetic acid | 110 |
| Petrol | 95 |
| Petroleum | 210 |
| Petroleum ether | 35 - 60 |
| Phenol | 182 |
| Phosgene | 8.3 |
| Phosphoric Acid | 213 |
| Propanal | 48 |
| Propane C3H8 | -42.04 |
| Propene | -47.72 |
| 2-Propanol | 82.2 |
| Propionic acid | 141 |
| Propylamine | 47.2 |
| Propylene | -47.7 |
| Propylene glycol | 187 |
| Salt solution, saturated brine aprox 26.4% | 108 |
| Styrene | 145 |
| Sulphur | 444.6 |
| Sulfuric Acid | 330 |
| Sulfur dichloride | 59.6 |
| Sulfur dioxide | -10 |
| Sulfur hexafluoride | -63.9 |
| Sulfuryl chloride | 69.4 |
| Tar | 300 |
| Toluene | 110.6 |
| Triptane | 80.9 |
| Triethanolamine | 350 |
| Turpentine oil | 160 |
| Water | 100 |
| Water, sea | 100.7 |
| Xenon | -108 |
| o-Xylene | 144.4 |
| m-Xylene | 139.1 |
| p-Xylene | 138.3 |
- T(oF) = (T(oC)) (9/5) + 32
- T(oC) = 5/9 (T(oF) - 32)
- Unit Converter
• Boiling Points of Fluids
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Chemicals - Formulas and Trading Names
Formulas and trading names for some common chemicals.
Condensate Pumping
High temperatures and danger of impeller cavitation is the major challenge for condensate pumping in steam systems.
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Density of Gases
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Fuels - Boiling Points
Fuels and their boiling points.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Glycerine - Boiling and Freezing Points
Boiling and freezing points of glycerine aqueous solutions.
Hydrocarbons - Physical Data
Liquid Densities
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
LPG - Liquefied Petroleum Gas
LPG or Liquefied Petroleum Gas.
Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Water - Boiling Points vs. Altitude
Elevation above sea level and the boiling point of water.
