Refrigerants - Physical Properties
Physical properties of some common refrigerants:
For full table with Freezing Points and Critical Points - rotate the screen!
Refrigerant
No.
NameMolecular Mass
(g/mol)
Boiling point
at atmospheric pressure 14.7 psia, 1 bar abs
(oF)
Freezing Point
(oF)
Critical Point
Temperature
(oF)
Pressure
(psia)
Specific Volume
(Cu.Ft./lb.)
R-10 Carbontetrachloride 153.8 170.2
R-11 Trichlorofluoromethane1) 137.37 74.9 -168 388 640 0.0289
R-12 Dichlorodifluoromethane2) 120.91 -21.8 -252 234 597 0.0287
R-13 Monochlorotrifluoromethane 104.46 -114.6 -294 84 561 0.0277
R-13B1 Bromotrifluoromethane 148.91 -72 -270 153 575 0.0215
R-14 Tetrafluoromethane (Carbon tetrafluoride) 88.00 -198.2 -299 -50 543 0.0256
R-14 Chloroform 119.4 142
R-21 Dichloro-fluoromethane 102.92 48.1 -211
R-22 Difluoromonochloromethane3) 86.468 -41.3 -256 205 722 0.0305
R-23 Trifluormethane 70 -119.9
R-30 Methylene Chloride 84.9 105.2
R-31 Monochloromonofluoromethane 68.5 48.0
R-32 Methylene Fluoride 52.0 -61.4
R-40 Chloromethane (Methyl Chloride) 50.488 -10.7 -144 290 969 0.0454
R-41 Methyl Fluoride 34.0 -109
R-50 Methane 16.044 -259 -296.6
R-110 Hexachloroethane 236.8 365
R-111 Pentachloromonofluoroethane 220.3 279
R-112 Tetrachlorodifluoroethane 203.8 199.0
R-113 Trichlorotrifluoroethane4) 187.39 118 -31 417 499 0.0278
R-114 1,2-dichloro-1,1,2,2-tetrafluoroethane 170.92 38.4 -137 294 473 0.0275
R-115 Chloropentafluoroethane 154.47 -38.0 -149 176 458 0.0261
R-116 Hexafluoroethane 138.0 -108.8
R-120 Pentachloroethane 202.3 324
R-123 Dichlorotrifluoroethane5) 152.93 82 -161 363 533
R-124 Monochlorotetrafluoroethane 136.5 10.4
R-125 Pentafluoroethane 120 -55
R-133a Monochlorotrifluoroethane 118.5 43.0
R-134a Tetrafluoroethane6) 102.03 -15 -142 214 590 0.0290
R-140a Trichloroethane 133.4 165
R-142b 1-chloro-1,1-difluoroethane 100.50 14 -204 279 598 0.0368
R-143a Trifluoroethane 84 -53.5
R-150a Dichloroethane 98.9 140
R-152a Difluoroethane 66.05 -13
R-160 Ethyl Chloride 64.515 12.2 -218
R-170 Ethane 30.070 -127 -278 90 710 0.0830
R-218 Octafluoropropane 188 -36.4
R-290 Propane 44.097 -44 -309.8 206 617 0.0728
RC-318 Octafluorocyclobutane 200.04 22 -43 240 404 0.0258
R-410A R-32 Difluoromethane (50% weight), R-125 Pentafluoroethane (50% weight) 72.6 -55.4   162 690
R-454B R-32 Difluoromethane (68.9% weight), R-1234yf 2,3,3,3-tetrafluoropropene (31.1% weight) 62.6 -58.9 173 764 0.037
R-500 Dichlorodifluoromethane/
Difluoroethane7)
99.31 -28 -254 222 642 0.0323
R-502 Chlorodifluoromethane/
111.63 -50   180 591 0.0286
R-503 Chlorotrifluoromethane/
Trifluoromethane
87.50 -128   67 607 0.0326
R-600 n-Butane 58.12 31.2 -217 306 551 0.0702
R-600a Isobutane (2-Methyl propane) 58.12 10.8 -229 275 529 0.0725
R-611 Methyl formate 60.05 89 -146 417 870 0.0459
R-702 Hydrogen 2.016 -423 -434.6
R-704 Helium 4.0026 -452
R-717 Ammonia 17.02 -28 -107.9 271 1657 0.0680
R-720 Neon 20.179 -410.9 -415.6
R-728 Nitrogen 28.0134 -320.4 -346
R-729 Air 28.966 -320 -357.2
R-732 Oxygen 31.9988 -297.3 -361.3
R-740 Argon 39.948 -303 -308.5
R-744 Carbon Dioxide 44.01 -109.4 -70 88 1070 0.0342
R-744A Nitrous Oxide 44.012 -127.3 -131.5
R-764 Sulfur Dioxide 64.06 14.0 -104 316 1143 0.0306
R-1150 Ethylene 28.05 -155 -272 49 742 0.0700
R-1270 Propylene 42.08 -54 -301 197 670 0.0720
1) Production of R11 or CFC-11 was halted by the clean air act on January 1, 1996
2) Production of R12 or CFC-12 (Dichlorodifluoromethane) was halted by the clean air act on January 1, 1996
3) R22 or HCFC-22 is a single component HCFC refrigerant with low ozone depletion potential. It has long been used in a variety of air-conditioning and refrigeration applications in a variety of markets, including appliance, construction, food processing, and supermarkets. Production of R-22 halted in U.S. 2015.
4) Production of R113 or CFC-113 was halted by the clean air act on January 1, 1996
5) R123 or HCFC-123 is a replacement for R11 in chillers and is providing this new refrigerant to chiller manufacturers for use in new and existing chillers
6) Refrigerant R134a or HFC-134a is a commercially available hydrofluorocarbon (HFC) refrigerant for use as a long-term replacement for R-12 in new equipment and for retrofitting medium temperature CFC-12 systems
7) Production of R-500 was halted by the clean air act on January 1, 1996.
Low Pressure, Medium Pressure and High Pressure Refrigerants
Typical low, medium and high pressure refrigerants are listed in the table below:
Refrigerants
Low Pressure R11 Trichlorofluoromethane
R13 Chlorotrifluoromethane
R113 Trichlorotrifluoroethane
R123 Dichlorotrifluoroethane
Medium Pressure R114 1,2-dichloro-1,1,2,2-tetrafluoroethane
High Pressure R12 Dichlorodifluoromethane
R22 Chlorodifluoromethane
R134a Tetrafluoroethane
R410A Difluoromethane/Pentafluoroethane
R500 Dichlorodifluoromethane/
Difluoroethane
R502 Chlorodifluoromethane/
CFC, HCFC, HFC and HC Refrigerants
Refrigerants can be classified as CFC's - ChloroFluoroCarbons refrigerants, HCFC's - HydroChloroFluorCarbons refrigerants, HFC's - HydroFluorCarbons refrigerants and HC - HydroCarbon refrigerants.
Refrigerants
CFC
ChloroFluoroCarbons
Difluoroethane
R503 Chlorotrifluoromethane/
Trifluoromethane
HCFC
R124 Chlorotetrafluoroethane
R401a R22(53%)/R152a(13%)/R124(34%)
R401b R22(61%)/R152a(11%)/R124(28%)
R402a R22(38%)/R125(60%)/R290(2%)
R403b R22(56%)/R218(39%)/R290(5%)
R406a R22(55%)/R600a(4%)/R142b(41%)
R408a R125(7%)/R143a(46%)/R22(47%)
R409a R22(60%)/R124(25%)/R142b(15%)
HFC
HydroFluorCarbons
R23 Trifluoromethane
R404a R125(44%)/R143a(52%)/R134a(4%)
R407a R32(20%)/R125(40%)/R134a(40%)
R410a R32(50%)/R125(50%)
R416a R134a(59%)/R124(39.5%)/R600(1.5%)
R507 R125(50%)/R143a(50%)
R508a R23(39%)/R116(61%)
HC
HydroCarbons
R600 butane
R600a iso-butane
Boiling Points of Fluids
Material Properties
Dichlorodifluoromethane - Properties
Properties of saturated liquid Dichlorodifluoromethane R-12 - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Dichlorodifluoromethane - Properties, Imperial Units
Properties of saturated liquid Dichlorodifluoromethane - CCl2F2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Global Temperature Trend
Global temperature trend year 1880 - 2015.
Net Refrigeration Effect
The quantity of heat absorbed from a refrigerated space.
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units.
Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity.
Refrigerant R134a - Properties
Thermodynamic properties of refrigerant R-134a.
Refrigerants - Color Codes
Common refrigerants and their color codes.
Refrigerants - Environmental Properties
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP).
Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A.
Refrigerants - Saturation Pressures vs. Temperatures
Temperature and pressure diagram for constant boiling refrigerants - imperial and SI units.
Substances Triple Points
Triple points for common substances.
