Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure charts for
- R22
- R410A
- R12
- R134A
- R401A
- R409A
- R502
- R404A
- R507A
- R408A
- R402A
Refrigerants Temperature and Pressure Chart - Imperial Units
Refrigerants Temperature and Pressure Chart - SI Units
• Air Conditioning
Dichlorodifluoromethane - Properties
Properties of saturated liquid Dichlorodifluoromethane R-12 - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Dichlorodifluoromethane - Properties, Imperial Units
Properties of saturated liquid Dichlorodifluoromethane - CCl2F2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Net Refrigeration Effect
The quantity of heat absorbed from a refrigerated space.
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units.
Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity.
Refrigerant R22 - Thermodynamic Properties
Thermodynamic properties of R22, like vapor volume, enthalpy and entropy at pressures from 30 to 260 psia.
Refrigerants
Commonly used refrigerants - the methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds.
Refrigerants - Environmental Properties
Physical and environmental properties of some common refrigerants.
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP).
Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Refrigerants - Saturation Pressures vs. Temperatures
Temperature and pressure diagram for constant boiling refrigerants - imperial and SI units.
