Dichlorodifluoromethane - Properties
Properties of saturated liquid Dichlorodifluoromethane - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number:
Temperature
- T -
(oC)
Density
- ρ -
(kg/m3)
Specific Heat
- cp -
(103 J/(kg K))
Thermal Conductivity
- k -
(W/(m K))
Kinematic Viscosity
- ν -
(10-6 m2/s)
Prandtl Number
- Pr -
-50 1547 0.875 0.067 0.310 6.2
-40 1519 0.885 0.069 0.279 5.4
-30 1490 0.896 0.069 0.253 4.8
-20 1461 0.907 0.071 0.235 4.4
-10 1429 0.920 0.073 0.221 4.0
0 1397 0.935 0.073 0.214 3.8
10 1364 0.950 0.073 0.203 3.6
20 1330 0.966 0.073 0.198 3.5
30 1295 0.984 0.071 0.194 3.5
40 1257 1.002 0.069 0.191 3.5
50 1216 1.022 0.069 0.190 3.5
  • 1 kg/m3 =  0.0624 lb/ft3
  • 1 J/(kg K) = 2.389×10-4 kcal/(kg oC) = 2.389×10-4 Btu/lbmoF
  • 1 W/(m K) = 0.85984 kcal/(h m oC) = 0.5779 Btu/(ft h oF) = 0.048 Btu/(in h oF)
  • 1 m2/s = 104 St = 106 cSt = 10.764 ft2/s= 38750 ft2/h
Dichlorodifluoromethane - R-12 - is a chlorofluorocarbon halomethane used as a refrigerant and aerosol spray propellant. Manufacturing was discontinued in 1995 due to concerns about damage to the ozone layer.
Material Properties
Dichlorodifluoromethane - Properties, Imperial Units
Properties of saturated liquid Dichlorodifluoromethane - CCl2F2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity.
Refrigerants
Commonly used refrigerants - the methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds.
Refrigerants - Color Codes
Common refrigerants and their color codes.
Refrigerants - Environmental Properties
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP).
Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A.
