Dichlorodifluoromethane - Properties, Imperial Units
Properties of saturated liquid Dichlorodifluoromethane - R-12 - CCl2F2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number:
Dichlorodifluoromethane - Properties - Imperial Units
Temperature
- T -
(oF)
Density
- ρ -
(lbm/ft3)
Specific Heat
- cp -
(Btu/lbmoF)
Thermal Conductivity
- k -
(Btu/(h ft oF))
Kinematic Viscosity
- ν -
(10-5 ft2/s)
Prandt'l No.
- Pr -
-58 96.56 0.2090 0.039 0.334 6.2
-22 92.99 0.2139 0.040 0.272 4.8
14 89.24 0.2198 0.042 0.238 4.0
32 87.24 0.2232 0.042 0.230 3.8
68 83.04 0.2307 0.042 0.213 3.5
104 78.48 0.2393 0.040 0.206 3.5
122 75.91 0.2440 0.039 0.204 3.5
Dichlorodifluoromethane R-12 is a chlorofluorocarbon halomethane used as a refrigerant and aerosol spray propellant. Manufacturing was discontinued in 1995 due to concerns about damage to the ozone layer.
Material Properties
Properties of saturated liquid Dichlorodifluoromethane R-12 - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
Refrigerants - Color Codes
Common refrigerants and their color codes.
Refrigerants - Environmental Properties
Physical and environmental properties of some common refrigerants.
Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A.
