h l = enthalpy of vapor leaving evaporator (Btu/lb , J/kg)
h e = enthalpy of vapor entering evaporator (Btu/lb , J/kg)
Common refrigerants and their color codes.
Physical and environmental properties of some common refrigerants.
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A.
Calculate compression work, coefficients of performance and more.
