(oF)
For full table with Enthalpy and Entropy in Liquid and Vapor - rotate the screen!
Temperature (oC) | Absolute Pressure (bar) | Density Liquid (kg/m3) | Density Vapor (kg/m3) | Enthalpy Liquid (kJ/kg) | Enthalpy Vapor (kJ/kg) | Entropy Liquid (kJ/(kgK)) | Entropy Vapor (kJ/(kgK)) |
-60 | 0.15935 | 1472.0 | 0.9291 | 24.491 | 261.491 | 0.68772 | 1.8014 |
-50 | 0.29477 | 1444.9 | 1.6526 | 36.302 | 267.779 | 0.74358 | 1.7809 |
-40 | 0.51225 | 1417.0 | 2.773 | 48.631 | 274.068 | 0.79756 | 1.76448 |
-30 | 0.84379 | 1388.2 | 4.4307 | 61.130 | 280.324 | 0.84995 | 1.75142 |
-20 | 1.32719 | 1358.4 | 6.7903 | 73.833 | 286.513 | 0.901 | 1.74113 |
-10 | 2.00575 | 1327.4 | 10.047 | 86.777 | 292.598 | 0.95095 | 1.73309 |
0 | 2.,92769 | 1295.1 | 14.433 | 1000.0 | 298.536 | 1 | 1.72684 |
10 | 4.14571 | 1261.2 | 20.226 | 113.540 | 304.276 | 1.04834 | 1.72196 |
20 | 5.71665 | 1225.5 | 27.773 | 127.437 | 309.756 | 1.09613 | 1.71806 |
30 | 7.70132 | 1187.5 | 37.517 | 141.736 | 314.892 | 1.14354 | 1.71473 |
40 | 10.1648 | 1146.7 | 50.055 | 156.491 | 319.575 | 1.19073 | 1.71152 |
50 | 13.1773 | 1102.2 | 66.234 | 171.778 | 323.652 | 1.23794 | 1.70792 |
60 | 16.8156 | 1052.9 | 87.346 | 187.715 | 326.896 | 1.28548 | 1.70325 |
70 | 21.1668 | 996.49 | 115.564 | 204.515 | 328.941 | 1.3339 | 1.6965 |
80 | 26.3336 | 928.78 | 155.130 | 222.616 | 329.095 | 1.38434 | 1.68585 |
90 | 32.4489 | 838.51 | 216.936 | 243.168 | 325.655 | 1.43978 | 1.66692 |
100 | 39.7254 | 649.71 | 367.064 | 273.641 | 309.037 | 1.5198 | 1.61466 |
1,1,1,2-Tetrafluoroethane - R-134a - is an inert gas used primarily as a high-temperature refrigerant for domestic refrigeration and automobile air conditioners.
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
Commonly used refrigerants - the methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds.
Physical and environmental properties of some common refrigerants.
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP).
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Temperature and pressure diagram for constant boiling refrigerants - imperial and SI units.
