Boiling Liquids - Max Pumping Flow Velocities
As a rule of thumb - max recommended velocities on the delivery sides when pumping boiling liquids:
Pipe Dimensions | Boiling Liquids | ||
inches | mm | m/s | ft/s |
1 | 25 | 1 | 3.5 |
2 | 50 | 1.1 | 3.6 |
3 | 75 | 1.15 | 3.8 |
4 | 100 | 1.25 | 4 |
6 | 150 | 1.5 | 4.7 |
8 | 200 | 1.75 | 5.5 |
10 | 250 | 2 | 6.5 |
12 | 300 | 2 | 6.5 |
• Piping Systems
• Pumps
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Fuels - Boiling Points
Fuels and their boiling points.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
Steel Pipes Schedule 40 - Velocity Head vs. Water Flow
Velocity head can be used to calculate minor pressure or head loss in fluid flow systems.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
