Flow (gal/min) | 2 1/2" | 3" | 4" | |||
Velocity - v - (ft/s) | Velocity Head - v2/2g - (ft) | Velocity - v - (ft/s) | Velocity Head - v2/2g - (ft) | Velocity - v - (ft/s) | Velocity Head - v2/2g - (ft) | |
14 | 0.94 | 0.014 | ||||
16 | 10.7 | 0.018 | ||||
18 | 1.21 | 0.023 | ||||
20 | 1.34 | 0.028 | ||||
22 | 1.47 | 0.034 | 0.95 | 0.026 | 0.55 | 0.005 |
24 | 1.61 | 0.040 | 1.04 | 0.036 | 0.60 | 0.006 |
26 | 1.74 | 0.047 | 1.13 | 0.047 | 0.66 | 0.007 |
28 | 1.88 | 0.055 | 1.22 | 0.059 | 0.71 | 0.008 |
30 | 2.01 | 0.063 | 1.3 | 0.073 | 0.76 | 0.009 |
35 | 2.35 | 0.086 | 1.52 | 0.089 | 0.88 | 0.012 |
40 | 2.68 | 0.112 | 1.74 | 0.105 | 1.01 | 0.016 |
45 | 3.02 | 0.141 | 1.95 | 0.124 | 1.14 | 0.020 |
50 | 3.35 | 0.174 | 2.17 | 0.143 | 1.26 | 0.025 |
55 | 3.69 | 0.211 | 2.39 | 0.165 | 1.39 | 0.030 |
60 | 4.02 | 0.251 | 2.6 | 0.187 | 1.51 | 0.036 |
65 | 4.36 | 0.295 | 2.82 | 0.211 | 1.64 | 0.042 |
70 | 4.69 | 0.342 | 3.04 | 0.237 | 1.76 | 0.048 |
75 | 5.03 | 0.393 | 3.25 | 0.264 | 1.89 | 0.056 |
80 | 5.36 | 0.447 | 3.47 | 0.293 | 2.02 | 0.063 |
85 | 5.70 | 0.504 | 3.69 | 0.354 | 2.15 | 0.071 |
90 | 6.03 | 0.565 | 3.91 | 0.421 | 2.27 | 0.080 |
95 | 6.37 | 0.630 | 4.12 | 0.495 | 2.40 | 0.089 |
100 | 6.70 | 0.698 | 4.34 | 0.574 | 2.52 | 0.099 |
110 | 7.37 | 0.844 | 4.77 | 0.659 | 2.77 | 0.119 |
120 | 8.04 | 1.00 | 5.21 | 0.749 | 3.02 | 0.142 |
130 | 8.71 | 1.18 | 5.64 | 0.846 | 3.28 | 0.167 |
140 | 9.38 | 1.37 | 6.08 | 0.948 | 3.53 | 0.193 |
150 | 10.05 | 1.57 | 6.51 | 1.06 | 3.78 | 0.22 |
160 | 10.7 | 1.79 | 6.94 | 1.17 | 4.03 | 0.253 |
170 | 11.4 | 2.02 | 7.38 | 1.42 | 4.28 | 0.285 |
180 | 12.1 | 2.26 | 7.81 | 1.69 | 4.54 | 0.320 |
190 | 12.7 | 2.52 | 8.25 | 1.98 | 4.79 | 0.356 |
200 | 13.4 | 2.79 | 8.68 | 2.29 | 5.04 | 0.395 |
220 | 14.7 | 3.38 | 9.55 | 2.63 | 5.54 | 0.478 |
240 | 16.1 | 4.02 | 10.4 | 3.0 | 6.05 | 0.569 |
260 | 17.4 | 4.72 | 11.3 | 3.38 | 6.55 | 0.667 |
280 | 18.8 | 5.47 | 12.2 | 3.79 | 7.06 | 0.774 |
300 | 20.1 | 6.28 | 13.0 | 4.23 | 7.56 | 0.888 |
320 | 13.9 | 4.68 | 8.06 | 1.01 | ||
340 | 8.57 | 1.14 | ||||
360 | 9.07 | 1.28 | ||||
380 | 9.58 | 1.43 | ||||
400 | 10.1 | 1.58 | ||||
420 | 10.6 | 1.74 | ||||
440 | 11.1 | 1.91 | ||||
460 | 11.6 | 20.9 | ||||
480 | 12.1 | 2.27 | ||||
500 | 12.6 | 2.47 | ||||
550 | 13.9 | 2.99 | ||||
600 | 15.1 | 3.55 | ||||
650 | 16.4 | 4.17 | ||||
700 | 17.6 | 4.84 |
Flow (gal/min) | 5" | 6" | 8" | |||
40 | 0.64 | 0.006 | 0.44 | 0.003 | 0.26 | 0.001 |
50 | 0.80 | 0.010 | 0.56 | 0.005 | 0.32 | 0.002 |
60 | 0.96 | 0.014 | 0.67 | 0.007 | 0.39 | 0.002 |
70 | 1.12 | 0.020 | 0.78 | 0.009 | 0.45 | 0.003 |
80 | 1.28 | 0.026 | 0.89 | 0.012 | 0.51 | 0.004 |
90 | 1.44 | 0.032 | 1.0 | 0.016 | 0.58 | 0.005 |
100 | 1.60 | 0.040 | 1.11 | 0.019 | 0.67 | 0.006 |
120 | 1.92 | 0.058 | 1.33 | 0.028 | 0.77 | 0.009 |
140 | 2.25 | 0.078 | 1.55 | 0.038 | 0.90 | 0.013 |
160 | 2.57 | 0.102 | 1.78 | 0.049 | 1.03 | 0.016 |
180 | 2.89 | 0.129 | 2.0 | 0.062 | 1.15 | 0.021 |
200 | 3.21 | 0.160 | 2.22 | 0.077 | 1.28 | 0.026 |
220 | 3.53 | 0.193 | 2.44 | 0.093 | 1.41 | 0.031 |
240 | 3.85 | 0.230 | 2.66 | 0.110 | 1.54 | 0.037 |
260 | 4.17 | 0.270 | 2.89 | 0.130 | 1.67 | 0.043 |
280 | 4.49 | 0.313 | 3.11 | 0.150 | 1.80 | 0.050 |
300 | 4.81 | 0.360 | 3.33 | 0.172 | 1.92 | 0.058 |
320 | 5.13 | 0.409 | 3.55 | 0.196 | 2.05 | 0.066 |
340 | 5.45 | 0.462 | 3.78 | 0.222 | 2.18 | 0.074 |
360 | 5.77 | 0.518 | 4.0 | 0.240 | 2.31 | 0.083 |
380 | 6.09 | 0.577 | 4.22 | 0.277 | 2.44 | 0.092 |
400 | 6.41 | 0.639 | 4.44 | 0.307 | 2.57 | 0.102 |
420 | 6.74 | 0.705 | 4.66 | 0.338 | 2.7 | 0.113 |
440 | 7.06 | 0.774 | 4.89 | 0.371 | 2.83 | 0.124 |
460 | 7.38 | 0.846 | 5.11 | 0.405 | 2.96 | 0.135 |
480 | 7.7 | 0.921 | 5.33 | 0.442 | 3.08 | 0.147 |
500 | 8.02 | 1.0 | 5.55 | 0.479 | 3.21 | 0.160 |
550 | 8.82 | 1.21 | 6.11 | 0.580 | 3.53 | 0.193 |
600 | 9.62 | 1.44 | 6.66 | 0.690 | 3.85 | 0.230 |
650 | 10.4 | 1.69 | 7.22 | 0.810 | 4.17 | 0.271 |
700 | 11.2 | 1.96 | 7.77 | 0.939 | 4.49 | 0.313 |
750 | 12.0 | 2.25 | 8.33 | 1.08 | 4.81 | 0.360 |
800 | 12.8 | 2.56 | 8.88 | 1.23 | 5.13 | 0.409 |
850 | 13.6 | 2.89 | 9.44 | 1.38 | 5.45 | 0.462 |
900 | 14.4 | 3.24 | 9.99 | 1.55 | 5.77 | 0.518 |
950 | 15.2 | 3.61 | 10.5 | 1.73 | 6.09 | 0.577 |
1000 | 16.0 | 4.0 | 11.1 | 1.92 | 6.41 | 0.639 |
1100 | 17.6 | 4.84 | 12.2 | 2.32 | 7.05 | 0.773 |
1200 | 19.2 | 5.76 | 13.3 | 2.76 | 7.70 | 0.920 |
1300 | 20.8 | 6.75 | 14.4 | 3.24 | 8.34 | 1.08 |
1400 | 22.5 | 7.83 | 15.5 | 3.76 | 8.98 | 1.25 |
1500 | 24.1 | 8.99 | 16.7 | 4.31 | 9.62 | 1.44 |
1600 | 25.7 | 10.2 | 17.8 | 4.91 | 10.3 | 1.64 |
1700 | 27.3 | 11.6 | 18.9 | 5.54 | 10.9 | 1.85 |
1800 | 28.8 | 12.9 | 20.0 | 6.21 | 11.5 | 2.07 |
1900 | 30.5 | 14.4 | 21.1 | 6.92 | 12.2 | 2.31 |
2000 | 32.1 | 16.0 | 22.2 | 7.67 | 12.8 | 2.56 |
2200 | 24.4 | 9.27 | 14.1 | 3.09 | ||
2400 | 26.6 | 11.1 | 15.4 | 3.68 | ||
2600 | 16.7 | 4.32 | ||||
2800 | 18.0 | 5.01 | ||||
3000 | 19.2 | 5.75 |
Recommended max suction flow velocity when pumping boiling fluids.
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Major and minor loss in pipes, tubes and duct systems.
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Recommended maximum flow velocities in water systems on the delivery side of the pump.
