Fuels - Boiling Points
The boiling point of a substance is the temperature at which it can change state from a liquid to a gas throughout the bulk of the liquid.
The boiling point is defined as the temperature at which the saturated vapor pressure of a liquid is equal to the surrounding atmospheric pressure.
Some fuels and their boiling points at atmospheric pressure:
FuelBoiling Point
(oF)
Acetaldehyde 70
Acetone 134
Acetylene -119.2
Benzene 176.2
Butylene 21.2
Ethyl Alcohol 172
Ethane -127.5
Ethylene -154.7
Fuels Oil No.1 304 - 574
Gasoline 100 - 400
IsoButane 10.9
Isobutene 19.6
Isopropyl alcohol 181
Iso-Octane 243.9
IsoPentane 82.2
Kerosine 304 - 574
Methane (Natural Gas) -258.7
Methyl Alcohol 149
n-Butane 31.1
n-Heptane 209.1
n-Hexane 155.7
n-Octane 258.3
n-Pentane 97.0
n-Pentene 86.0
Naphthalene 424.4
NeoPentane 49.1
NeoHexane 121.5
Propane -43.8
Propylene -53.9
Triptane 177.6
Toluene 231.1
Xylene 281.1
Boiling Points of Fluids
Combustion
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Combustion Appliances - Exhaust Temperatures
Exhaust and outlet temperatures fuels like natural gas, liquefied petroleum, diesel and more.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Fuels - Densities and Specific Volumes
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
Higher Calorific Values of Common Fuels: Reference & Data
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
LPG - Gas Properties
Liquefied Petroleum - LP - gas properties.
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
