LPG - Gas Properties
Liquefied petroleum gas, also called LPG, GPL, LP or autogas, is a flammable mixture of hydrocarbon gases.
PropertyButanePropane
Btu per cu. ft. (60oF) 3280 2516
Btu per lb. 21221 21591
Btu per gal. 102032 91547
Cu. ft. per lb. 6.506 8.58
Cu. ft. per gal. 31.26 36.69
Lb. per. gal. 4.81 4.24
Gases and Compressed Air
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Fuels - Boiling Points
Fuels and their boiling points.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
