See also other properties of Propane at varying temperature and pressure : Density and specific weight , Dynamic and Kinematic Viscosity , Prandtl number , Specific heat (heat capacity) , Thermal conductivity and Thermal diffusivity , and Thermophysical properties at standard conditions .
Adiabatic flame temperatures for hydrogen, methane, propane and octane - in Kelvin.
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Vapor and saturation pressure for some common liquids.
Liquefied Petroleum - LP - gas properties.
Resistance and pressure loss in liquid LPG pipes.
Required capacities of relief valves on LPG vaporizers and tanks.
Latent heat with vaporized propane.
Energy content and specific gravity of propane air mixtures.
