Propane Air Mixture
The diagrams below indicates the energy content and specific gravity of propane air mixtures:
Energy Content - Btu/cu.ft
Energy Content - kJ/Nm3
Gases and Compressed Air
LPG - Liquefied Petroleum Gas
LPG or Liquefied Petroleum Gas.
LPG Tanks - Relief Valves Capacities
Required capacities of relief valves on LPG vaporizers and tanks.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Thermal Diffusivity vs. Temperature and Pressure
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
