Propane - Thermal Diffusivity vs. Temperature and Pressure
Thermal diffusivity is the rate of transfer of heat of a material from the hot side to the cold side - a measure of how quickly a material can absorb heat from its surroundings. It can be calculated by taking the thermal conductivity divided by density and specific heat capacity at constant pressure.
Thermal diffusivity has the SI derived unit of (m²/s) , and is usually denoted α but a, κ, K, and D are also used. The formula is:
α =k / (ρ CP) (1)
k = is thermal conductivity (W/(m·K))
ρ = density (kg/m³)
CP = specific heat capacity (J/(kg·K))
Below, thermal diffusivity of propane at varying temperatures and 1, 10, 50 and 100 bara (14.5, 145, 725 and 1450 psia) are given in figures and tables.
See also other properties of propane at varying temperature and pressure: Density and specific weight, Dynamic and Kinematic Viscosity, Prandtl number, Specific heat (heat capacity), Thermal conductivity, and Thermophysical properties at standard conditions,
as well as thermal diffusivity of air, nitrogen and water .
Thermal diffusivity of propane at 1, 10 and 100 bara (14.5, 145 and 1450 psia), and varying temperature given as °C or °F:
Thermal diffusivity of propane at atmospheric pressure and given temperature, SI and Imperial units:
| State | Temperature | Thermal diffusivity | Temperature | Thermal diffusivity | |||||
| (K) | (°C) | (×10-6 m2/s) | (m2/h) | (K) | (°F) | (×10-5 ft2/s) | ( ft2/h) | ||
| Liquid | 123 | -150 | 0.142 | 0.000510 | 116 | -250 | 0.154 | 0.00555 | |
| 148 | -125 | 0.134 | 0.000482 | 144 | -200 | 0.146 | 0.00524 | ||
| 173 | -100 | 0.124 | 0.000448 | 172 | -150 | 0.134 | 0.00484 | ||
| 198 | -75 | 0.114 | 0.000410 | 200 | -100 | 0.122 | 0.00438 | ||
| 223 | -50 | 0.103 | 0.000369 | 228 | -50 | 0.108 | 0.00390 | ||
| 231 | -42 | 0.09896 | 0.000356 | 231 | -44 | 0.107 | 0.00384 | ||
| Gas | 231 | -42 | 3.68 | 0.0132 | 231 | -44 | 3.88 | 0.140 | |
| 248 | -25 | 4.33 | 0.0156 | 244 | -20 | 4.88 | 0.176 | ||
| 263 | -10 | 4.94 | 0.0178 | 255 | 0 | 5.76 | 0.207 | ||
| 268 | -5 | 5.14 | 0.0185 | 266 | 20 | 6.69 | 0.241 | ||
| 273 | 0 | 5.35 | 0.0193 | 272 | 30 | 7.18 | 0.259 | ||
| 278 | 5 | 5.56 | 0.0200 | 278 | 40 | 7.68 | 0.276 | ||
| 283 | 10 | 5.78 | 0.0208 | 283 | 50 | 8.19 | 0.295 | ||
| 293 | 20 | 6.22 | 0.0224 | 294 | 70 | 9.26 | 0.333 | ||
| 298 | 25 | 6.44 | 0.0232 | 300 | 80 | 9.82 | 0.353 | ||
| 303 | 30 | 6.67 | 0.0240 | 305 | 90 | 10.4 | 0.374 | ||
| 323 | 50 | 7.61 | 0.0274 | 311 | 100 | 11.0 | 0.395 | ||
| 348 | 75 | 8.86 | 0.0319 | 339 | 150 | 14.1 | 0.509 | ||
| 373 | 100 | 10.2 | 0.0367 | 366 | 200 | 17.8 | 0.639 | ||
| 398 | 125 | 11.6 | 0.0418 | 394 | 250 | 21.8 | 0.786 | ||
| 423 | 150 | 13.1 | 0.0473 | 422 | 300 | 26.4 | 0.951 | ||
| 448 | 175 | 14.8 | 0.0532 | 478 | 400 | 37.3 | 1.34 | ||
| 473 | 200 | 16.5 | 0.0594 | 533 | 500 | 50.7 | 1.83 | ||
| 523 | 250 | 20.3 | 0.0730 | 589 | 600 | 67.0 | 2.41 | ||
| 573 | 300 | 24.5 | 0.0884 | 644 | 700 | 86.4 | 3.11 | ||
| 623 | 350 | 29.3 | 0.106 | 700 | 800 | 109 | 3.94 | ||
| 673 | 400 | 34.7 | 0.125 | 755 | 900 | 136 | 4.90 | ||
| 773 | 500 | 47.1 | 0.170 | 811 | 1000 | 167 | 6.02 | ||
Thermal diffusivity of propane at given temperature and pressure, SI and Imperial units:
| State | Temperature | Pressure | Thermal diffusivity | ||||
| (K) | (°C) | (°F) | (bara) | (psia) | (×10-6 m2/s) | (×10-5ft2/s) | |
Liquid at equilibrium |
100 | -173 | -280 | 2.5E-07 | 3.7E-06 | 0.149 | 0.160 |
| 130 | -143 | -226 | 0.000176 | 0.00255 | 0.140 | 0.151 | |
| 160 | -113 | -172 | 0.00850 | 0.1233 | 0.130 | 0.140 | |
| 190 | -83.2 | -118 | 0.1055 | 1.530 | 0.117 | 0.126 | |
| 220 | -53.2 | -63.7 | 0.6058 | 8.787 | 0.104 | 0.112 | |
| 250 | -23.2 | -9.7 | 2.180 | 31.62 | 0.0902 | 0.0971 | |
| 280 | 6.9 | 44.3 | 5.817 | 84.37 | 0.0772 | 0.0831 | |
| 310 | 36.9 | 98.3 | 12.73 | 184.6 | 0.0650 | 0.0699 | |
| 320 | 46.9 | 116 | 15.99 | 231.9 | 0.0609 | 0.0656 | |
| 340 | 66.9 | 152 | 24.32 | 352.7 | 0.0512 | 0.0551 | |
| 355 | 81.9 | 179 | 32.43 | 470.4 | 0.0394 | 0.0425 | |
| 360 | 86.9 | 188 | 35.55 | 515.6 | 0.0345 | 0.0371 | |
Gas at equilibrium |
100 | -173 | -280 | 2.5E-07 | 3.7E-06 | 1921257 | 2068022 |
| 130 | -143 | -226 | 0.000176 | 0.00255 | 5460 | 5877 | |
| 160 | -113 | -172 | 0.00850 | 0.1233 | 187 | 201 | |
| 190 | -83.2 | -118 | 0.1055 | 1.530 | 22.2 | 23.9 | |
| 220 | -53.2 | -63.7 | 0.6058 | 8.787 | 5.13 | 5.52 | |
| 250 | -23.2 | -9.7 | 2.180 | 31.62 | 1.73 | 1.86 | |
| 280 | 6.9 | 44.3 | 5.817 | 84.37 | 0.729 | 0.785 | |
| 310 | 36.9 | 98.3 | 12.73 | 184.6 | 0.341 | 0.367 | |
| 320 | 46.9 | 116 | 15.99 | 231.9 | 0.264 | 0.284 | |
| 340 | 66.9 | 152 | 24.32 | 352.7 | 0.151 | 0.163 | |
| 355 | 81.9 | 179 | 32.43 | 470.4 | 0.0800 | 0.0861 | |
| 360 | 86.9 | 188 | 35.55 | 515.6 | 0.0552 | 0.0594 | |
| Liquid | 85.53 | -187.62 | -305.72 | 1 | 14.5 | 0.148 | 0.159 |
| 100 | -173 | -280 | 1 | 14.5 | 0.147 | 0.158 | |
| 120 | -153 | -244 | 1 | 14.5 | 0.142 | 0.153 | |
| 140 | -133 | -208 | 1 | 14.5 | 0.137 | 0.147 | |
| 160 | -113 | -172 | 1 | 14.5 | 0.130 | 0.139 | |
| 180 | -93.2 | -136 | 1 | 14.5 | 0.122 | 0.131 | |
| 200 | -73.2 | -99.7 | 1 | 14.5 | 0.113 | 0.122 | |
| 220 | -53.2 | -63.7 | 1 | 14.5 | 0.104 | 0.112 | |
| 230.74 | -42.41 | -44.34 | 1 | 14.5 | 0.0992 | 0.107 | |
| Gas | 230.74 | -42.41 | -44.34 | 1 | 14.5 | 3.36 | 3.62 |
| 240 | -33.2 | -27.7 | 1 | 14.5 | 3.70 | 3.98 | |
| 260 | -13.2 | 8.3 | 1 | 14.5 | 4.46 | 4.80 | |
| 280 | 6.9 | 44.3 | 1 | 14.5 | 5.26 | 5.66 | |
| 300 | 26.9 | 80.3 | 1 | 14.5 | 6.09 | 6.56 | |
| 320 | 46.9 | 116 | 1 | 14.5 | 6.96 | 7.50 | |
| 340 | 66.9 | 152 | 1 | 14.5 | 7.88 | 8.48 | |
| 360 | 86.9 | 188 | 1 | 14.5 | 8.84 | 9.51 | |
| 400 | 127 | 260 | 1 | 14.5 | 10.9 | 11.7 | |
| 500 | 227 | 440 | 1 | 14.5 | 17.1 | 18.4 | |
| 600 | 327 | 620 | 1 | 14.5 | 25.1 | 27.0 | |
| 700 | 427 | 800 | 1 | 14.5 | 35.1 | 37.7 | |
| 800 | 527 | 980 | 1 | 14.5 | 47.3 | 50.9 | |
| 900 | 627 | 1160 | 1 | 14.5 | 62.1 | 66.8 | |
| 1000 | 727 | 1340 | 1 | 14.5 | 79.6 | 85.7 | |
| Liquid | 85.62 | -187.53 | -305.55 | 10 | 145 | 0.148 | 0.159 |
| 100 | -173 | -280 | 10 | 145 | 0.147 | 0.158 | |
| 120 | -153 | -244 | 10 | 145 | 0.143 | 0.154 | |
| 140 | -133 | -208 | 10 | 145 | 0.137 | 0.147 | |
| 160 | -113 | -172 | 10 | 145 | 0.130 | 0.140 | |
| 180 | -93.2 | -136 | 10 | 145 | 0.122 | 0.131 | |
| 200 | -73.2 | -99.7 | 10 | 145 | 0.113 | 0.122 | |
| 220 | -53.2 | -63.7 | 10 | 145 | 0.105 | 0.112 | |
| 240 | -33.2 | -27.7 | 10 | 145 | 0.0955 | 0.103 | |
| 260 | -13.2 | 8.3 | 10 | 145 | 0.0866 | 0.0933 | |
| 280 | 6.9 | 44.3 | 10 | 145 | 0.0779 | 0.0839 | |
| 300.09 | 26.94 | 80.49 | 10 | 145 | 0.0692 | 0.0745 | |
| Gas | 300.09 | 26.94 | 80.49 | 10 | 145 | 0.435 | 0.468 |
| 320 | 46.9 | 116 | 10 | 145 | 0.553 | 0.595 | |
| 340 | 66.9 | 152 | 10 | 145 | 0.668 | 0.719 | |
| 360 | 86.9 | 188 | 10 | 145 | 0.782 | 0.842 | |
| 400 | 127 | 260 | 10 | 145 | 1.02 | 1.10 | |
| 500 | 227 | 440 | 10 | 145 | 1.69 | 1.81 | |
| 600 | 327 | 620 | 10 | 145 | 2.51 | 2.70 | |
| 700 | 427 | 800 | 10 | 145 | 3.54 | 3.81 | |
| 800 | 527 | 980 | 10 | 145 | 4.78 | 5.15 | |
| 900 | 627 | 1160 | 10 | 145 | 6.28 | 6.76 | |
| 1000 | 727 | 1340 | 10 | 145 | 8.05 | 8.67 | |
| Liquid | 100 | -173 | -280 | 50 | 725 | 0.150 | 0.161 |
| 200 | -73.2 | -99.7 | 50 | 725 | 0.115 | 0.124 | |
| 300 | 26.9 | 80.3 | 50 | 725 | 0.0734 | 0.0790 | |
| Supercritical phase |
400 | 127 | 260 | 50 | 725 | 0.102 | 0.110 |
| 500 | 227 | 440 | 50 | 725 | 0.300 | 0.322 | |
| Liquid | 86.45 | -187 | -304 | 100 | 1450 | 0.149 | 0.160 |
| 100 | -173 | -280 | 100 | 1450 | 0.148 | 0.159 | |
| 120 | -153 | -244 | 100 | 1450 | 0.144 | 0.155 | |
| 140 | -133 | -208 | 100 | 1450 | 0.139 | 0.150 | |
| 160 | -113 | -172 | 100 | 1450 | 0.133 | 0.143 | |
| 180 | -93.2 | -136 | 100 | 1450 | 0.125 | 0.135 | |
| 200 | -73.2 | -99.7 | 100 | 1450 | 0.117 | 0.126 | |
| 220 | -53.2 | -63.7 | 100 | 1450 | 0.109 | 0.117 | |
| 240 | -33.2 | -27.7 | 100 | 1450 | 0.101 | 0.108 | |
| 260 | -13.2 | 8.3 | 100 | 1450 | 0.0925 | 0.0996 | |
| 280 | 6.9 | 44.3 | 100 | 1450 | 0.0849 | 0.0913 | |
| 300 | 26.9 | 80.3 | 100 | 1450 | 0.0779 | 0.0838 | |
| 320 | 46.9 | 116 | 100 | 1450 | 0.0716 | 0.0771 | |
| 340 | 66.9 | 152 | 100 | 1450 | 0.0660 | 0.0711 | |
| 360 | 86.9 | 188 | 100 | 1450 | 0.0611 | 0.0658 | |
400 | 127 | 260 | 100 | 1450 | 0.0538 | 0.0579 |
| 500 | 227 | 440 | 100 | 1450 | 0.128 | 0.137 | |
| 600 | 327 | 620 | 100 | 1450 | 0.235 | 0.253 | |
| 700 | 427 | 800 | 100 | 1450 | 0.357 | 0.384 | |
| 800 | 527 | 980 | 100 | 1450 | 0.501 | 0.539 | |
| 900 | 627 | 1160 | 100 | 1450 | 0.669 | 0.720 | |
| 1000 | 727 | 1340 | 100 | 1450 | 0.865 | 0.931 | |
Unit conversion thermal diffusivity:
square feet/second (ft2/s), square feet/hour (ft2/h), square meter/hour (m2/h), square meter/second (m2/s)
- 1 ft2/h = 2.7778×10-4 ft2/s = 0.09290 m2/h = 2.581×10-5m2/s
- 1 ft2/s = 3600 ft2/h = 334.45 m2/h = 0.09290 m2/s
- 1 m2/h = 2.7778×10-4 m2/s = 10.7639 ft2/h = 0.002990 ft2/s
- 1 m2/s = 3600 m2/h = 38750.1 ft2/h = 10.7639 ft2/s
• Thermodynamics
Air - Prandtl Number
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Specific Heat vs. Temperature and Pressure
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Air Mixture
Energy content and specific gravity of propane air mixtures.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
Propane Gas Piping - Low Pressure Capacity vs. Size
Sizing of low pressure propane gas pipe lines - Imperial units.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
