Phase diagram of propane
Chemical, physical and thermal properties of Propane - C3 H8 :
(values at 25 oC (77 oF, 298 K) and atmospheric pressure)
Molecular Weight 44.097
Specific Gravity of gas (air = 1) 1.52
Specific Volume (ft3/lb, m3/kg) 8.84, 0.552
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) 36.2, 580
Vapor pressure at 25 oC (psia, MN/m2) 135.7, 0.936
Absolute Viscosity (lbm/ft s, centipoises) 5.38×10-6, 0.0074
Sound velocity in gas (m/s) 253
Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) 0.39, 1630
Specific Heat Ratio - cp/cv 1.13
Gas constant - R - (ft lb/lb oR, J/kg oC) 35.0, 188
Thermal Conductivity (Btu/hr ft oF, W/moC) 0.010, 0.017
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF, oC) -44, -42.2
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) 184, 428000
Freezing or Melting Point  at 1 atm (oF, oC) -309.8, -189.9
Latent Heat of Fusion (Btu/lb, J/kg) 19.1, 44400
Critical Temperature (oF, oC) 205, 96
Critical Pressure (psia, MN/m2) 618, 4.26
Critical Volume (ft3/lb, m3/kg) 0.073, 0.0045
Flammable yes
Heat of combustion (Btu/ft3, Btu/lb, kJ/kg) 2450, 21660, 50340
See the following documents for changes in propane properties with changes in pressure and temperature :
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Toluene, Water and Heavy water, D2O . Propane is a gas at standard conditions. However, at low temperature and/or high pressures the gas becomes a liquid (or a solid at very cold conditions).
The phase diagram for propane shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the propane boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
Combustion
Material Properties
Adiabatic Flame Temperatures
Adiabatic flame temperatures for hydrogen, methane, propane and octane - in Kelvin.
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Combustion Heat
Energy Content in common Energy Sources
Heating fuels and their energy content.
Fuel Gases - Flame Temperatures
Adiabatic flame temperatures for common fuel gases - propane, butane, acetylene and more - in air or oxygen atmospheres.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Higher Calorific Values of Common Fuels: Reference & Data
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
LPG - Gas Properties
Liquefied Petroleum - LP - gas properties.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Thermal Diffusivity vs. Temperature and Pressure
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
Propane Gas Piping - Low Pressure Capacity vs. Size
Sizing of low pressure propane gas pipe lines - Imperial units.
