See Triple point for listing of triple point values for common substances.
Substance | Critical temperature | Critical pressure | Boiling temperature (1 atm) | |||
[°F] | [°C] | [psi], [lb/in2] | [bar] | [°F] | [°C] | |
Air | -220.94 | -140.52 | 549.08 | 37.858 | - | - |
Ammonia (NH3) | 270 | 132.4 | 1636 | 112.8 | -27.4 | -33 |
Argon | -188 | -122 | 705.6 | 48.7 | -302.5 | -185.8 |
Butane | 305.6 | 152 | 550.4 | 38 | 32 | 0 |
Carbon-dioxide (CO2) | 87.8 | 31.2 | 1071.6 | 73.8 | -110 | -79 |
Carbon-monoxide (CO) | -220.5 | -140.3 | 507.5 | 35 | -310 | -190 |
Chlorine | 291 | 144 | 1118.7 | 77.1 | -29.3 | -34 |
Decane | 653 | 345 | 301.7 | 20.8 | 345 | 174 |
Dowtherm A | 465 | 32.1 | ||||
Ethane | 90.0 | 32.2 | 708 | 48.9 | -127.4 | -88.5 |
Ethanol (alcohol) | 467 | 242 | 914 | 63 | 173 | 78.4 |
Ethylether | 381 | 194 | 522 | 36 | 94.2 | 34.6 |
Ethylene | 48.9 | 9.4 | 735 | 50.7 | -272.6 | -169.2 |
Fluorine | -200 | -129 | 808.5 | 55.8 | -307 | -188 |
Helium | -456 | -271 | 33.2 | 2.3 | -452 | -269 |
Hydrogen (H) | -400 | -240 | 188.2 | 13.0 | -423 | -253 |
Hydrogen Chloride | 125 | 51.6 | 1198 | 82.7 | -121.1 | -85.1 |
Isobutane | 274 | 135 | 529.2 | 36.5 | 10.9 | -11.7 |
Isobutylene | 293 | 145 | 580 | 40.0 | 19.6 | -6.9 |
Isononane | 590 | 310 | 335.1 | 23.1 | 303 | 151 |
Methane | -117 | -82.6 | 673.3 | 46.5 | -259 | -162 |
Nitrogen (N) | -232.6 | -147 | 492.4 | 34.0 | -321 | -195 |
Nitrous Oxide (N2O) | 97.4 | 36.4 | 1047.6 | 72.3 | -127 | -88.5 |
Oxygen (O2) | -181.5 | -118.6 | 732 | 50.5 | -297 | -183 |
Phosgene | 823.2 | 56.8 | 46.9 | 8.3 | ||
Propane | 206.1 | 96.7 | 617.4 | 42.6 | -44 | -42 |
Propylbenzene | 689 | 365 | 464.2 | 32 | 319 | 159 |
Propylene | 198 | 92.4 | 670.3 | 46.3 | -54 | -48 |
Refrigerants | ||||||
Undecane | 691 | 366 | 287.2 | 19.8 | 385 | 196 |
Water | 705 | 374 | 3206.2 | 220.5 | 212 | 100 |
Chemical, Physical and Thermal Properties of Helium - He.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Critical pressure ratios for water and other liquids.
Triple points for common substances.
